Drill a magnum block for shaft rocker? #2710638
10/28/19 02:11 PM
10/28/19 02:11 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Has anybody drilled a magnum block for LA heads? Or successfully push rod oiled LA heads with a reasonably priced rocker?. If so what rocker arm? This is a 318 roller block that will be used with aluminum heads. Pro Comp or Eddy, 4" stroke. Street use only.
Doug
Re: Fill a magnum block for shaft rocker? [Re: dvw] #2710647
10/28/19 02:53 PM
10/28/19 02:53 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I've seen a couple threads on other boards where someone plumbed from the oil pressure port into the LA head through the back of the head. Requires a hole into the head and a hollowed out rocker shaft hold down bolt.
I think the PRW Stainless steel shaft rockers will oil through the pushrods and are probably your cheapest option.
Re: Fill a magnum block for shaft rocker? [Re: gzig5] #2710903
10/29/19 11:23 AM
10/29/19 11:23 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don’t see any reason why the Comp ultra-pro magnum rockers couldn’t be run as pushrod oiling.
Re: Drill a magnum block for shaft rocker? [Re: dvw] #2711093
10/30/19 05:47 AM
10/30/19 05:47 AM
MD
1965fish Offline
1965fish  Offline
MD
My machine shop made a jig and drilled my magnum block for LA heads.
Works great. Been racing the engine for years.
1965 Plymouth Barracuda Formula S
1965 Plymouth Valiant 200 Convertible
1965 Plymouth Valiant 200 Station wagon 408 6.52 @ 104
2001 Dodge Dakota 394 6.63 @ 103 1/8 mile 10.64 @ 123 1/4 mile
1965 Plymouth Valiant Signet 2DR HT
