Mopar performance cam? #2710405
10/27/19 03:48 PM
10/27/19 03:48 PM
USA
Lawn Monkey Offline OP
USA
What kind of cam lube comes with a Mopar performance cam? Back in the 80's Direct Connection came with a sticky grey brush on lube that did not run off . would like to buy that type if I knew what it was confused
Re: Mopar performance cam? [Re: Lawn Monkey] #2710483
10/27/19 09:41 PM
10/27/19 09:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
You have a PM on this thumbsscope
Re: Mopar performance cam? [Re: Lawn Monkey] #2710627
10/28/19 01:56 PM
10/28/19 01:56 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Absolutely nothing, unless they changed it since I left in '13, which is definitely possible.
Around 2011, we were told it would need to be shipped under some kind of regulation which sounded an awful lot like hazmat,
which we were told would eliminate sales in certain areas and slow down sales everywhere else. We also found out many customers
didn't like the cam lube and threw it away, so it was removed from all the kits.
Rich H.
Esse Quam Videri
