Anyone have this Engine Run Stand? #2710098
10/26/19 08:29 AM
10/26/19 08:29 AM
USA
Lawn Monkey Offline OP
USA
Anyone have one of these? Harbor freight / Walmart or Amazon Engine Run Stand 319-414 dollars , I sure its cheap import but will it work at least three times? I think I'm going to buy one as long as it will support a 440 Mopar work
https://www.amazon.com/Larin-METS-1-Mobile-Testing-Station/dp/B0007NXVB0
Re: Anyone have this Engine Run Stand? [Re: Lawn Monkey] #2710100
10/26/19 08:48 AM
10/26/19 08:48 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
here's my 340 on one, I did have to make a few mods to it. I got it on sale for $299 about a year ago. I'l try to get some pics from the rear or it today.
Re: Anyone have this Engine Run Stand? [Re: Mr340] #2710105
10/26/19 09:39 AM
10/26/19 09:39 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
You get what you pay for applies here but for a run stand intended for short term use they work just fine, (this is a Walmart $299.00 "El Cheepo" unit). I use one for carburetor testing on a 354 Hemi. It is a heavy engine but since I don't move it around much and basically never take it off and on the stand, it works fine. If you have a rough floor or an uneven surface you might consider higher-quality wheels, the supplied wheels don't like the weight much. I hand-built the radiator support of some simple 1.00" square tubing and also made a sheet metal plate to bolt the ignition components to.
Re: Anyone have this Engine Run Stand? [Re: ScottSmith_Harms] #2710106
10/26/19 09:47 AM
10/26/19 09:47 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I have since purchased a couple of Easy-Run stands which are a first class product. They also cost 5X's as much but again, you get what you pay for. There are also many homemade stands made from kits or plans which would work just as well (many members here have built them at home, some are very nice), just a matter of your skill level and budget.
Re: Anyone have this Engine Run Stand? [Re: Lawn Monkey] #2710111
10/26/19 10:03 AM
10/26/19 10:03 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I think the money would be better spent on taking the engine and putting it on a real dyno.
Re: Anyone have this Engine Run Stand? [Re: 71birdJ68] #2710127
10/26/19 11:06 AM
10/26/19 11:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Run stands are not Dynos (Real or otherwise) each has its place, just depends on what job you are using either for.
Re: Anyone have this Engine Run Stand? [Re: ScottSmith_Harms] #2710135
10/26/19 11:45 AM
10/26/19 11:45 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
iagree
Re: Anyone have this Engine Run Stand? [Re: Lawn Monkey] #2710137
10/26/19 11:56 AM
10/26/19 11:56 AM
Cab_Burge Online work
Cab_Burge  Online Work
You have a PM on one of the Wal Mart brands scope
Re: Anyone have this Engine Run Stand? [Re: 71birdJ68] #2710138
10/26/19 12:07 PM
10/26/19 12:07 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If I had to choose it would be the dyno, but it would be nice to have both.
Embarrassing to show up at the dyno with water, oil or crankcase vacuum leaks. Spending dyno money on fixing problems you could have found on a stand is not fun.
Re: Anyone have this Engine Run Stand? [Re: ScottSmith_Harms] #2710147
10/26/19 12:48 PM
10/26/19 12:48 PM
USA
USA
That's a really nice setup no doubt up I'm a shade tree hobby-est if I buy this Walmart/Amazon stand I see it being used twice for sure and maybe a time or two after that , with that in mind I'm going against my rule of always buy quality I very much agree with what you say "You get what you pay for" , I just hope it works some of the import stuff is just plane junk.
Re: Anyone have this Engine Run Stand? [Re: Lawn Monkey] #2710180
10/26/19 03:08 PM
10/26/19 03:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Most of the $299.00 specials I've seen (including my Walmart example) have been made up of a mix of bolt-together hollow thin wall tubes which are adequate but certainly no match for some of the higher quality examples. You could vastly improve any of them once bolted together by adding some reinforcing welds at all the bolted corners and some strategically located gussets here and there. That said I didn't add any to mine and its just fine, it just flexes a little when pushed around, nothing scarey.
Re: Anyone have this Engine Run Stand? [Re: ScottSmith_Harms] #2710221
10/26/19 06:33 PM
10/26/19 06:33 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I have a heavy duty one I started making in PA if anyone local is looking to buy one. It's probably 80% done and will include new gauges, a flywheel that will work on both big block and small block mopars, and the needed part to bolt a starter on a big block mopar. 280.00 but will not ship.
[Linked Image]engine stand 002 by John Cadamore, on Flickr
[Linked Image]engine stand 001 by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anyone have this Engine Run Stand? [Re: pittsburghracer] #2710308
10/27/19 07:38 AM
10/27/19 07:38 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Ignorant question here - what does one gain from using one of these short of leak detection? Engine break in?
Re: Anyone have this Engine Run Stand? [Re: larry4406] #2710310
10/27/19 07:58 AM
10/27/19 07:58 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Among other problems yes. A friend at work had an engine built and then built a stand to break it in before swapping it into a nice survivor 442.
It would also come in handy for selling engines as everyone wants to see it run before they buy. Many people have done this with front subframes but who wants that layin around?
Re: Anyone have this Engine Run Stand? [Re: larry4406] #2710319
10/27/19 08:59 AM
10/27/19 08:59 AM
USA
USA
I'm guessing you never wiped out a new cam on start up work, it sucks when that happens on a new install . It happen to me my challenger never left the parking spot had to pull the motor again the wiped lobe was now scattered around the interior of the engine fan
Re: Anyone have this Engine Run Stand? [Re: Lawn Monkey] #2710368
10/27/19 12:47 PM
10/27/19 12:47 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have had access to one on the last three builds that I have done this year. It is the only way to do it, IMO. Breaking in the cam, checking for rear main seal leaks, in my case, on the last one, brand new, out of the box mech fuel pump started leaking where the body is crimped together(Carter BB). Jetting and setting carbs, rerunning the valves after break-in, lots easier out of the car. If you are going to dyno it, it saves the frustration of having to do minor repairs then and lets you get on with what you came to do! No down side that I can see, except maybe storage.
Re: Anyone have this Engine Run Stand? [Re: larry4406] #2710369
10/27/19 12:48 PM
10/27/19 12:48 PM
Breaking in a new engine on the engine run stand or on a engine dyno is very helpful for controlling the cam break in procedure as well as leak detection, no scratching up the fenders or engine compartment also work
Re: Anyone have this Engine Run Stand? [Re: larry4406] #2710406
10/27/19 03:58 PM
10/27/19 03:58 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Yep. Both. I had a persistent oil leak on my hemi. I am glad it was on a run in stand instead of in the car. The cross ram is one heavy intake. And with flat tappet lifters was nice again to run it in before installing in the car.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
