Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks #2710017
10/25/19 04:19 PM
10/25/19 04:19 PM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
https://www.reuters.com/article/us-fiat-chrysler-recall-idUSKBN1X4286
Sample quote
The Italian-American automaker said the recall covers trucks from the 2014 through 2019 model years after finding microscopic cracks in some Exhaust Gas Recirculation coolers. The injuries occurred when customers attempted to manually extinguish engine compartment fires.
End quote
Re: Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks [Re: 360view] #2710089
10/26/19 01:58 AM
10/26/19 01:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
“ECO” Engines Coming Out
What a smoldering pile off poo! Buy a HEMI in a 1500 and you’ll be worlds ahead!!
Re: Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks [Re: 360view] #2710116
10/26/19 10:19 AM
10/26/19 10:19 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
In the past I had the thought that since Roger Penske had controlled the VM Motori company for several years that they would have above average engineering and production. Boy did this turn out to be wrong!
Maybe Penske sold it to Fiat because he decided it was beyond improvement.
Re: Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks [Re: 360view] #2710322
10/27/19 09:14 AM
10/27/19 09:14 AM
E
earlymopar Offline
earlymopar  Offline
E
I suspect the engine was fine as it was designed for and used for many years in boats. I would bet that the adaption to road use and the major re-tooling required for all part manufacturing, assembly, testing, etc, due to the major increase in volume is where things went wrong.
- EM
Re: Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks [Re: earlymopar] #2711142
10/30/19 09:44 AM
10/30/19 09:44 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Are VM Motori boat engines well thought of?
Are they more desired than Yanmar?
Re: Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks [Re: earlymopar] #2711167
10/30/19 10:45 AM
10/30/19 10:45 AM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
- EM
The EcoDiesel is not the first over the road application of this motor.
Maserati for one has used the 3.0 in a twin turbo, Non EGR variant.
EGR's are a huge issue with these, many owners have had multiple cooler failures and the EGR sticking open leads to the plastic intake manifold melting and burning the truck down.
I have had zero problems but the only reason I still own it is the factory emissions V08 recall gives you a huge extension in emissions warranty.
Kevin
Re: Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks [Re: BIGGERED] #2714662
11/10/19 10:06 PM
11/10/19 10:06 PM
Missouri
galen Offline
galen  Offline
Missouri
- EM
Kevin
Same here. Zero problems with mine. Extended warranty is nice, plus 3 months until paid off. 19 to 21 mpg city in an extended cab 4x4 is nice. Torn whether to keep it or not.
Re: Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks [Re: galen] #2714716
11/11/19 09:25 AM
11/11/19 09:25 AM
E
earlymopar Offline
earlymopar  Offline
E
Like many I opted to not go through the recall as the majority of trucks that have had the "upgrade" lose performance and mileage and are often times difficult to drive due to extreme delays in throttle response. The strange thing about the upgrade is the inconsistency reported by owners who's trucks have gone through it. Extended warranty aside, the better option in my opinion is the GDE or other aftermarket controller upgrades rather than the "factory" upgrade.
- EM
Re: Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks [Re: earlymopar] #2715323
11/13/19 01:24 AM
11/13/19 01:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I would say 80% of those who opt for the recall come back complaining of poor throttle response. Our line guy is doing number lucky 13 engine replacement. At least when they go, there is no doubt it failed.
Re: Recall: 2014-2019 Ram 1500 diesel EGR coolant leaks [Re: earlymopar] #2715460
11/13/19 04:12 PM
11/13/19 04:12 PM
ky.
K
kenworth_goose Offline
K
ky.
- EM
I'm having an Issue with my new 2500 Cummins and a rear diff wine, I'm scared to death to take it to the dealer because I know the first thing they will do is cut it's nuts with a new program. Fairly common practice for them. They try to mask an issue with a deprogramming so to speak.
