Switching to led tail lights.
#2709648
10/23/19 08:40 PM
10/23/19 08:40 PM
Posts: 1,032 illinois
bigblk66_coronet
illinois
i bought some led tail light bulbs for my 66 coronet and only one side works. put the old bulbs back in and they work. Somebody said something about getting a no load flasher? anyone run into this problem? What flasher did you use?
66 Dodge Coronet 500
440w/727
11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust
Best ET. 12.38 @110 in street trim
Re: Switching to led tail lights.
[Re: bigblk66_coronet]
#2709667
10/23/19 09:41 PM
10/23/19 09:41 PM
Posts: 1,810 North Dakota
Azzkikrcuda
North Dakota
If you are having an issue with the blinkers you will need a Electric flasher relay. Any parts store should have them.
The only Carbs I care about are under the hood!
