A body 4 speed shifter rods
#2709505
10/23/19 12:44 PM
10/23/19 12:44 PM
Posts: 2,270 St.Louis, MO
694406
St.Louis, MO
I bought a new set of shifter rods for my 69 cuda. The reverse shifter rod is formed/bent in the exact opposite direction as the original and will not clear when flipped around. Has anyone dealt with this? Thanks!
www.Musclemagnet.com1969 Cuda 383 Q5 1969 Cuda 340 4-spd Notch 1969 Cuda 383 4-spd Notch 1969 GTS Black on White 340 4-spd 1971 Cuda 383 V2, X9 Billboards, White Top!
Re: A body 4 speed shifter rods
[Re: 694406]
#2709934
10/25/19 08:35 AM
10/25/19 08:35 AM
Posts: 766 Ohio
Dan Brewer
Ohio
[Re: Dan Brewer]
#2709963
10/25/19 10:57 AM
10/25/19 10:57 AM
694406
St.Louis, MO
[Re: 694406]
#2709968
10/25/19 11:09 AM
10/25/19 11:09 AM
694406
St.Louis, MO
Original in place vs the new one. when hooked up as original it seems it's bent/ formed 180 off?
[Re: 694406]
#2710007
10/25/19 02:09 PM
10/25/19 02:09 PM
Posts: 766 Ohio
Dan Brewer
Ohio
[Re: Cab_Burge]
#2710130
10/26/19 11:25 AM
10/26/19 11:25 AM
694406
St.Louis, MO
I'm thinking that may be the plan. Only modification is I'll have to grind down the adjustable part or drill out the reverse lever. Heck I'm wondering how hard it would be to bend the rod in the correct configuration?
[Re: 694406]
#2710336
10/27/19 10:26 AM
10/27/19 10:26 AM
Posts: 19,396 north of coder
moparx
i believe those rods are pretty stiff material. heat would definitely be needed, and once used, may take the temper out of the rod. if it were me, i would get the correct rod and be done with it. or contact the place you got the rods from and see if they would exchange that particular rod.
