Re: Recommendations to clean fuel tank
[Re: vinnyd76]
#2709109
10/22/19 09:14 AM
10/22/19 09:14 AM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
If the tank is in good shape inside,I used acetone and some crushed stone to swish it around with the sending unit removed. Acetone does evaporate so act in a timely manner. Rinse with water,use compressed air to dry or let air dry. Other people may recommend a different method,but this worked for me and had no issues. Hope this helps
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 68Cbarge]
#2709173
10/22/19 12:44 PM
10/22/19 12:44 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
I used a POR 15 kit in my 65s tank That was like 25 years ago.It was plain nasty and bad.Used it as per directuins and sealed it.Changed senders like 8 years ago and still looked new inside.Well worth the money.I did let it sit in the sun and dry before I used sealer.Then let it sit in the sun a day or so so it cured.Rocky
Chrysler Firepower
[Re: gzig5]
#2709546
10/23/19 02:49 PM
10/23/19 02:49 PM
Posts: 211 Halifax, VA.
moparjack44
Halifax, VA.
[quote=gzig5]. I did one 30+ years ago by dumping in about 3 pounds of 1/4-3/8 nuts and bolts and swishing them around with acetone or something like it.
I used a decent size chain on my 48 DeSoto fuel tank. So far (about 20 years), no problems.
K.I.S.S.
