Page 1 of 3 1 2 3
904 Transmission gurus..... #270862
03/29/09 08:24 PM
03/29/09 08:24 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
What is the upgarde for a strong 904 that is behind a 360 ? What is it exactly I have to do/change for better strenght of the ttransmission ?
Any infos please..
Daniel
Re: 904 Transmission gurus..... [Re: Wedgeman] #270863
03/29/09 08:45 PM
03/29/09 08:45 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
How HP is the 360 ? .. how heavy is the car ?
Re: 904 Transmission gurus..... [Re: dOc …] #270864
03/29/09 10:34 PM
03/29/09 10:34 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i put 5 clutches in the front clutch pac using the thin clutches and steels..
for racing...i change out the big spring in the front clutch to the 24 small spring set up...
outside that and the valve body the trans is stock.
Tony
70 AARCuda Vitamin C
Re: 904 Transmission gurus..... [Re: 70AARcuda] #270865
03/29/09 11:07 PM
03/29/09 11:07 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
For 5 disc, I have to change the clutch housing, more room for 5 disc can I take it from a A-500 ?
Or on what type of vehicule can I expect to find this set up ?
Daniel
Re: 904 Transmission gurus..... [Re: Wedgeman] #270866
03/29/09 11:27 PM
03/29/09 11:27 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
this is what i have done to several 904s
removed the 4 clutch/steels...
installed the 5 clutch/steels..using the thin ones..i get about 50-55 thousands clearance which i think is too tight... I take the pressure plate that is in the clutch pac to machine shop..have about .020 removed to get .070-.075 clearance..
so i am using stock clutch/drum..and stock pump.
Tony
Re: 904 Transmission gurus..... [Re: 70AARcuda] #270867
03/30/09 01:09 AM
03/30/09 01:09 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Neat !!!!
These are my first pointers on transmissions...
Daniel
Re: 904 Transmission gurus..... [Re: Wedgeman] #270868
03/30/09 01:51 AM
03/30/09 01:51 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
A good starting point is a '76 or later trans, they have most of the good mods done over the years by the factory. One of the weak points in the earlier trans's is they have aluminium planetary gear carriers which have been known to either chew the splines out or split in half. The '76 and later ones all had steel planetary carriers.
Re: 904 Transmission gurus..... [Re: Mcode69] #270869
03/30/09 10:19 AM
03/30/09 10:19 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
OK ! thanks, another good info
Daniel
Re: 904 Transmission gurus..... [Re: Wedgeman] #270870
03/30/09 10:32 AM
03/30/09 10:32 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Like was said you can fit 5 thin plates in a 4 clutch drum. Be carefull machining parts for clearance though. Take too much off and the steels won't engage the lugs in the drum.
You can upgrade to stock 5 clutch parts so you can use 5 thick plates but you need to swap both clutch drums and the front pump housing.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 904 Transmission gurus..... [Re: CJK440] #270871
03/30/09 11:02 AM
03/30/09 11:02 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
AARCUDA...
As stated, wouldn't it be better to dump my 67 and start with a later one ? '80-up ?
Daniel
Re: 904 Transmission gurus..... [Re: Wedgeman] #270872
03/30/09 12:47 PM
03/30/09 12:47 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
AARCUDA...
Daniel
if you are talking about the whole trans ..probably yes.
but I would not mix parts unless you are positive they work.
actually the 72 and newer 904 are better due to a change in the servos...
some of the 904 came with 5 clutches aka 999 in the 80s.
mine are used for bracket racing and so far it has worked for me.
Tony
Re: 904 Transmission gurus..... [Re: 70AARcuda] #270873
03/30/09 02:04 PM
03/30/09 02:04 PM
New Mexico
74Scamp Offline
74Scamp  Offline
New Mexico
AARCUDA...
Daniel
Don't mean to hijack this thread, but for a mild 360, would you still machine to get the .70 to .75? Mine is a 999 and I'm getting ready to start putting it back together this weekend and was just wondering (my first tranny rebuild).
Re: 904 Transmission gurus..... [Re: 74Scamp] #270874
03/30/09 02:06 PM
03/30/09 02:06 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
No problems.....btw...how do you tell a 904 from a 999 ?
Daniel
Re: 904 Transmission gurus..... [Re: Wedgeman] #270875
03/30/09 02:09 PM
03/30/09 02:09 PM
New Mexico
74Scamp Offline
74Scamp  Offline
New Mexico
Not sure from the outside, but inside has the 5-disc clutch pak from the factory. Mine came out of a 78 Diplomat Police car.
Re: 904 Transmission...suite [Re: 74Scamp] #270876
03/30/09 02:13 PM
03/30/09 02:13 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
OK....because it was a police car set up.......?
Daniel
Re: 904 Transmission gurus..... [Re: Wedgeman] #270877
03/30/09 02:27 PM
03/30/09 02:27 PM
New Mexico
74Scamp Offline
74Scamp  Offline
New Mexico
Yes. I think that's correct. I was, at one time (a couple years ago) told that was what I wanted to look for - a police car.
Re: 904 Transmission gurus..... [Re: 74Scamp] #270878
03/30/09 03:01 PM
03/30/09 03:01 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
AARCUDA...
Daniel
what i have read...again no experts...
.015 per clutch....075 for 5
.060 for 4...
Tony
Re: 904 Transmission gurus..... [Re: 70AARcuda] #270879
03/30/09 04:03 PM
03/30/09 04:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Another good thing about the early 80s trans is the low gear ratio 1st and 2nd gear sets they have.
When I build a 4 clutch drum into a 5 clutch unit I just change the snap ring thickness. Usually combining 2 thin flat snaprings and useing the thick waffle clutches you can get 5 in there. I don't like the flat ones because the fuid takes longer to get out from between them, the clutches will hydro plane over each other for a second. If my pack is still tight I might slide one flat clutch in there just to get the clearance.
Another good mod is to remove the wavy snap rings and install flat rings, this reduces slipage during engagement.
If you use the trans go kit don't be afraid to drill the shift holes to the max size, it still is not a hard shift.
One more thing I like to do is run type F fluid for an even faster shift.
Re: 904 Transmission gurus.....(suite..) [Re: HotRodDave] #270880
03/30/09 04:18 PM
03/30/09 04:18 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Wow.....that's a lot to assimilate......I'll work on all these infos..
Ok...took the trans apart looks great.....Is this the picture of worn clutches ? looks fine to me....has it been rebuilt ? or just a polite previous owner ?
Comments please....
Also.....yes the planetray carrier is aluminum...
Re: 904 Transmission ..(suite..) [Re: Wedgeman] #270881
03/31/09 03:05 PM
03/31/09 03:05 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Do you think I still need to rebuild it ?
it's going behind a 360
Or I could get an '87 model that was in a Fifth Ave car with a 318 ?
Daniel
Page 1 of 3 1 2 3
