Re: 904 Transmission gurus.....
[Re: dOc !]
#270864
03/29/09 10:34 PM
03/29/09 10:34 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
i put 5 clutches in the front clutch pac using the thin clutches and steels..
for racing...i change out the big spring in the front clutch to the 24 small spring set up...
outside that and the valve body the trans is stock.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Wedgeman]
#270866
03/29/09 11:27 PM
03/29/09 11:27 PM
70AARcuda
las vegas
this is what i have done to several 904s
removed the 4 clutch/steels...
installed the 5 clutch/steels..using the thin ones..i get about 50-55 thousands clearance which i think is too tight... I take the pressure plate that is in the clutch pac to machine shop..have about .020 removed to get .070-.075 clearance..
so i am using stock clutch/drum..and stock pump.
Tony
[Re: 70AARcuda]
#270873
03/30/09 02:04 PM
03/30/09 02:04 PM
Posts: 1,488 New Mexico
74Scamp
New Mexico
AARCUDA...
As stated, wouldn't it be better to dump my 67 and start with a later one ? '80-up ?
Daniel
if you are talking about the whole trans ..probably yes.
but I would not mix parts unless you are positive they work.
actually the 72 and newer 904 are better due to a change in the servos...
some of the 904 came with 5 clutches aka 999 in the 80s.
mine are used for bracket racing and so far it has worked for me.
Don't mean to hijack this thread, but for a mild 360, would you still machine to get the .70 to .75? Mine is a 999 and I'm getting ready to start putting it back together this weekend and was just wondering (my first tranny rebuild).
Re: 904 Transmission gurus.....(suite..)
[Re: HotRodDave]
#270880
03/30/09 04:18 PM
03/30/09 04:18 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Wow.....that's a lot to assimilate......I'll work on all these infos.. Ok...took the trans apart looks great.....Is this the picture of worn clutches ? looks fine to me....has it been rebuilt ? or just a polite previous owner ? Comments please.... Also.....yes the planetray carrier is aluminum...
Re: 904 Transmission ..(suite..)
[Re: Wedgeman]
#270881
03/31/09 03:05 PM
03/31/09 03:05 PM
Wedgeman
Do you think I still need to rebuild it ? it's going behind a 360
Or I could get an '87 model that was in a Fifth Ave car with a 318 ?
Daniel
