WHAT STARTER ? #2707958
10/18/19 09:36 AM
10/18/19 09:36 AM
On the parachute mount
N
n20mstr Online content OP
n20mstr  Online Content OP
N
Ive seen these threads before...BUT I have a Mopar Mini already. WHat I have is a 13.7 comp and a 12v battery. Now its starting to kick back, backfire etc. Not good. Im making the switch to a litium 16v. Next step is a better starter ? WHat brand ?
....BAD A$$ STREET CAR.....
Re: WHAT STARTER ? [Re: n20mstr] #2707962
10/18/19 09:42 AM
10/18/19 09:42 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Change to a 16 v ..
Or, I run two big 12 volt batteries from Napa .. the really big ones
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: WHAT STARTER ? [Re: bigdad] #2708035
10/18/19 12:04 PM
10/18/19 12:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a Powermaster on the Stratus with a 16V Lithium Pros battery and no issues and this engine is fairly difficult to turn over by hand as it has 60MM Babbit gearings and a fair amount of spring. The dragster has an XS 16V with a Mopar mini starter with zero issues, I did purchase a Powermaster for it as well but so far zero issues with the Mopar mini
Re: WHAT STARTER ? [Re: n20mstr] #2708038
10/18/19 12:09 PM
10/18/19 12:09 PM
Washington
madscientist Offline
Washington
If you are already running two 12 volt batteries skip the 16 volt deal. Buy a series parallel switch and run the starter off 24 volts. With that switch, only the starter gets 24 volts and everything else always gets 12 volts.
Much better way to do it than going to 16 volt stuff.
Re: WHAT STARTER ? [Re: madscientist] #2708041
10/18/19 12:29 PM
10/18/19 12:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My Lithium battery weighs just over 9lbs, the XS in the dragster weighs 30lbs. Both way better options that 90 plus pounds of battery in the car..
Re: WHAT STARTER ? [Re: n20mstr] #2708044
10/18/19 12:35 PM
10/18/19 12:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Tuneup? Have you tried killing the ignition until the starter gets up to speed?
Re: WHAT STARTER ? [Re: John_Kunkel] #2708049
10/18/19 12:42 PM
10/18/19 12:42 PM
N
N
YES, still turns over slow. The battery is almost three years old. And its only one group 24 12volt
Re: WHAT STARTER ? [Re: n20mstr] #2708056
10/18/19 12:50 PM
10/18/19 12:50 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Man you guys have lots of starter issues.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: WHAT STARTER ? [Re: pittsburghracer] #2708079
10/18/19 12:58 PM
10/18/19 12:58 PM
N
N
it starts ok, just looking to get rid of the occasional kickback. And im switching to 16V anyway...so that may actually be it. THis 12v is getting old and im sure the alternator I use is not covering the amp draw.
Re: WHAT STARTER ? [Re: n20mstr] #2708114
10/18/19 02:46 PM
10/18/19 02:46 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I ran a supplementary -ve cable from the batteries to the starter, wow what a difference.
Re: WHAT STARTER ? [Re: Tig] #2708120
10/18/19 03:17 PM
10/18/19 03:17 PM
America
WedgeFED Offline
WedgeFED  Offline
America
RobbMC builds an excellent starter, truly clocks in any position. Well worth the money.
https://www.robbmcperformance.com/products/mopar_starter.html
Re: WHAT STARTER ? [Re: n20mstr] #2708135
10/18/19 04:09 PM
10/18/19 04:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run the Mopar mini at 15-1. Cold; If you pump the throttle a few times and let it set 30 seconds, one more pump and it fires in one revolution. Hot; one pump 10-15 seconds, same result. Waiting is key.
Doug
Re: WHAT STARTER ? [Re: dvw] #2708148
10/18/19 04:41 PM
10/18/19 04:41 PM
N
N
Doug
ITS FUNNY you mention that. I have a digital water temp gauge. Ive been doing two pumps under 90*, one pump over 90*. Never waited. And yea I think I need more fuel in the engine because a kick back is really just a lean pop ?
Re: WHAT STARTER ? [Re: n20mstr] #2708175
10/18/19 07:29 PM
10/18/19 07:29 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've had issues on staring similar to yours but I think it is ignition box and or grounding issues, not low amperage from the batteries shruggy
I'm going to do some rewiring this winter along with taking another MSD7AL2 box and a MSD digital non programmable box and another MSD transformer coil and two of the early red coils for the 7AL2 race boxes and see if I can figure out exactly where my car starting problems are work wrench grin
I'll post the results and my thought on what caused what when I'm done thumbs
Re: WHAT STARTER ? [Re: Cab_Burge] #2708228
10/18/19 11:22 PM
10/18/19 11:22 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
My slow start is not the battery or starter solonoid. I will replace my 10 year old mopar mini with another. 9:1 static CR.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: WHAT STARTER ? [Re: n20mstr] #2708320
10/19/19 12:34 PM
10/19/19 12:34 PM
On the stock car it would get cranky when hot. I started cranking it THEN switching on the ign while cranking & that took care of it. Ground your coil wire & try it & see if that takes care of it
Re: WHAT STARTER ? [Re: n20mstr] #2708465
10/20/19 09:43 AM
10/20/19 09:43 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Be sure to run an equal size grounding cable to match your 12V+ cable in every location, especially from battery to starter, to ignition and to both heads. Also, as mentioned a few times above, using an ignition 12v+ cut-off switch to allow the motor to start cranking at full speed before flipping the switch to light it works nicely.
As to your posted question, I have an MSD starter in one of my vehicles. It turned out to be overkill, because once I updated my grounds, even an old junkyard starter cranked my stuff over really well.
Re: WHAT STARTER ? [Re: jbc426] #2708468
10/20/19 09:55 AM
10/20/19 09:55 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Local parts store vs. Power Master:
[Linked Image]Untitled by Greg Ault, on Flickr
Re: WHAT STARTER ? [Re: RapidRobert] #2708496
10/20/19 11:06 AM
10/20/19 11:06 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Can you explain what coil wire do you ground? confused
Re: WHAT STARTER ? [Re: Sammy] #2708706
10/20/19 11:03 PM
10/20/19 11:03 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I run a RobbMC starter , I cranks the 572 Hemi with no problem. What I have found is that a lot of guys use the body/frame as a ground . I did years ago and had slow cranking like the batteries were not up to the task. I ran a #2 cable from the trunk mounted battery ground post to the starter/ bell housing bolt. What a difference it made, engine cranked over like a new car.
