62-65 b body auto trans mount dimensions??? #2707372
10/16/19 08:01 PM
10/16/19 08:01 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
anyone have one laying around that could tell me the distance from the top of the mount where it bolts to trans to the bottom where it bolts to xmember?
Thanks!
Re: 62-62 auto trans mount dimensions??? [Re: Blown61] #2707392
10/16/19 08:49 PM
10/16/19 08:49 PM
my early (63-66) early A body Energy Suspension "poly" trans mount is 3&3/8" & from what I understand auto & manual are the same. EDIT I looked it up & this one fits 1962-1973 Dart (so I would assume fits the other A bodies of those years).
Re: 62-62 auto trans mount dimensions??? [Re: RapidRobert] #2707398
10/16/19 09:15 PM
10/16/19 09:15 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Thank you!
Re: 62-62 auto trans mount dimensions??? [Re: RapidRobert] #2707405
10/16/19 09:22 PM
10/16/19 09:22 PM
Oh I missed that you said B body. I would go to www.energysuspension.com & hit "download catalog" then scroll down to page 36 & the # is 5.1112 & it has the apps that it fits & it includes some B bodies (not sure if back to 62 or not) I bought mine for an early A body & from top to bottom (not including the stud) is 3&3/8" on the nose. EDIT I went back over there & it fits 62-70 Belvedere
Re: 62-62 auto trans mount dimensions??? [Re: RapidRobert] #2707409
10/16/19 09:35 PM
10/16/19 09:35 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Thanks again!!!
Re: 62-62 auto trans mount dimensions??? [Re: RapidRobert] #2707449
10/17/19 12:09 AM
10/17/19 12:09 AM
1962 Dart where bodies, not A bodies tsk
1963 and later Darts where A bodies up
The 1960 to 1962 Mopar A bodies came in two different brands, Chrysler Lancers, maybe Dodge ?????? (CRS whiney), no Plymouth A bodies from 1960 to 1962.
the Hyper pack slant six with the four barrel and four speeds started in 1960 or 1961,the 273 LA motors where introduced in mid year 1964 with the single exhaust and two barrel carbs only for the rest oft hat year I what I remember I think they added the four barrel, bigger cam and higher compression ratio in the beginning of 1965 on the 273 in both brands of the A body , not late 1964 confused shruggy
Re: 62-62 auto trans mount dimensions??? [Re: Cab_Burge] #2707631
10/17/19 12:46 PM
10/17/19 12:46 PM
Quote
1962 Dart were B bodies, not A bodies.
You're right
Re: 62-62 auto trans mount dimensions??? [Re: RapidRobert] #2707670
10/17/19 02:23 PM
10/17/19 02:23 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I think the trans mount was the same for many years.
Reason I think that is I used a '69 B mount in my '63 Savoy when converting it from 3-speed stick to A833.
I used the same part when converting my '64 savoy from 3-speed stick to A727.
Could be a '62 is different as there are a lot of parts unique to them.
Oh, and I believe a 60-62 Plymouth A body would be the Valiant, though technically it wasn't assigned to the Plymouth line in '60.
The 61-62 Lancer was the Dodge equivalent to the Valiant, of course.
Re: 62-62 auto trans mount dimensions??? [Re: topside] #2708351
10/19/19 03:46 PM
10/19/19 03:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Actually no B bodys in 62 IIRC first B body was 65.Rocky
Chrysler Firepower
Re: 62-62 auto trans mount dimensions??? [Re: therocks] #2708360
10/19/19 04:32 PM
10/19/19 04:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Mopar Performance catalog shows B-body as '62-'79.
Re: 62-62 auto trans mount dimensions??? [Re: John_Kunkel] #2708453
10/20/19 08:41 AM
10/20/19 08:41 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We know MP could never screw up.IIRC first b designation was 65.Rocky
Chrysler Firepower
Re: 62-62 auto trans mount dimensions??? [Re: therocks] #2708611
10/20/19 05:18 PM
10/20/19 05:18 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
so, anyone have the dimensions for a 62-65 b body trans mount?
Re: 62-62 auto trans mount dimensions??? [Re: Blown61] #2708790
10/21/19 10:03 AM
10/21/19 10:03 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I just removed one yesterday from a 65 Bel II auto car...
Everything looks to be original and unmolested from a 69,000 mile car...
Two studs on the bottom of the mount thru the crossmember...
The distance from the inside of the bottom of the crossmember to mounting flange for the transmission is 2 15/16"...
...FAFO...
Re: 62-62 auto trans mount dimensions??? [Re: skicker] #2708873
10/21/19 01:44 PM
10/21/19 01:44 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
AWESOME!!! thank you very much!!
