Re: What happened to my paint ?
[Re: topside]
#2707377
10/16/19 08:12 PM
10/16/19 08:12 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
I hired an experienced body /painter to do this. It's popping up in different areas - painted 2 years ago - whats the best approach to fix or does it need to be all redone.
68 Satellite Wagon and a few other ones
[Re: mro]
#2707385
10/16/19 08:22 PM
10/16/19 08:22 PM
Posts: 20,841 A collage of whims
topside
A collage of whims
The correct fix is to sand into it and find the problem, you'll need to go at least into the primer if not down to bare metal. Look for signs of rust (water in air lines, or getting on car during repairs). Also, an excessive amount of primer or polyester could be the issue. Check the whole car over very thoroughly, and find out what refinish system (or different products) were used. On occasion, a shop painter that's certified in a given system, and can prove that to the tech rep, will stand behind the work. Other times, unfortunately, not so much.
[Re: modelmakerinc]
#2707507
10/17/19 08:02 AM
10/17/19 08:02 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
PPG certified painter here. from looking at the pic. to me it looks like the clear coat is de-laminating from the base coat. there might be some contamination, like dirt, oil, moisture, on top of the base
is it only happening in 1 spot or all over the car? how long was the base coat open before clearing? what type of air supply equipment when painted?
i myself would first start with talking to the person painting the car and see what he thinks.
perception is 90% of reality
[Re: Mr T2U]
#2707510
10/17/19 08:21 AM
10/17/19 08:21 AM
mro
Lynch Road
Its happening in a couple spots. Its unlikely rust because its on 2 different panels (so far) and both were pristine. I picked up the car about 2 years ago and garaged it - that's it - I did call the painter - and sent pics - haven't heard back. I looks like specs on the clear coat - almost like sap after you park under a tree - a few places - you can feel it better then you can see it
[Re: mro]
#2707514
10/17/19 08:43 AM
10/17/19 08:43 AM
Posts: 2,345 west palm beach, florida
modelmakerinc
it is not de-laminating clear, Clear-coats look milky when they separate from the base-coat, the lifting is happening under the paint and/or primer. I would say it is spider rust forming
[Re: mro]
#2707515
10/17/19 08:45 AM
10/17/19 08:45 AM
Mr T2U
a physical inspection is required to really diagnose it best.
in my opinion it looks like moisture contamination to me. 15 years ago a shop a old friend worked at had a similar problem. it was actually one of the prep men use shower to shower . the talcum from his hands transferred to the body and it worked thru to the top coat causing a similar problem. ever since i always use a solvent based AND a water based pre-cleaner before painting.
to repair will require a strip and re-paint.
[Re: mro]
#2707588
10/17/19 11:09 AM
10/17/19 11:09 AM
Posts: 15,457 Omaha Ne
TJP
Omaha Ne
The pictures appear to be blisters. Tree sap will normally eat into the paint leaving a slight depression behind. As the others have said, it's likely contamination of some sort under the paint but could also be due to incompatibility of of materials used. What layer it is at can only be established by carefully peeling back the blister. The layer where the peeling stops and the paint stays behind (IE: Primer , spot putty etc is where the problem is. The contamination is creating a gas (pressure), that in turn lifts the paint stretching it. While doing so it creates the bubble.\ Parking the car in the hot sun usually accelerates the process. Depending on how many areas are affected and the root cause will determine the repair process. A complete strip to bare metal and repaint may be the only sure way to eliminate future issues.
[Re: TJP]
#2707639
10/17/19 12:57 PM
10/17/19 12:57 PM
Posts: 4,156 Canada -- Posts: 4034 -Registe...
5thAve
What you have pictured is one way it can look when it starts to rust under the paint, usually where there's filler of some sort. Not always but usually if it's a chemical reaction or contamination there are signs of it starting before 2 years.
