Re: Internal balance cast crank
[Re: fastmark]
#2706836
10/14/19 09:25 PM
10/14/19 09:25 PM
Posts: 31,086 Oregon
AndyF
Yes you can drill the flywheel to balance it. The instructions are in one of the Mopar books. Any good machine shop should be able to do that if the engine is apart. If the engine is together then it is tougher since the shop will have to assume what the imbalance is.
I'd think your best bet would be to buy the correct flywheel.
[Re: fastmark]
#2706988
10/15/19 12:42 PM
10/15/19 12:42 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Is it possible to balance a cast crank motor internally without heavy metal ? Which type motor, SB or BB? I believe all the cast crank 318 motors where internally balanced
