904 output shaft bearing number...
#527382
11/16/09 12:17 AM
11/16/09 12:17 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I posted a while back looking for a source that sells replacement output shaft bearings for a 904. My car is away in storage right now, so I cant pull it apart. Is there anyone that has a 904 with the tailshaft housing off of it that could maybe get me the number off of the bearing? I have been calling and searching for a while now. All I can find are 727 bearings, which obviously do me no good.
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: 904 output shaft bearing number...
[Re: JohnRR]
#527384
11/16/09 01:37 AM
11/16/09 01:37 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
http://www.transmissionpartsusa.com/A727...0-00054688a.htmthis is listed under 904 but went you click on the link it takes you to a 727 bearing...dont know if they are the same but the dimensions are there.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 69L78Nova]
#527386
11/16/09 11:45 AM
11/16/09 11:45 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Did you try it ? They changed the 904 bearing sometime in the 70's , the early bearing is impossible to find , not available , I've never found one .
Is the one in your trans bad ? transstar # is 12976 for the TF-6
