Instrument voltage regulator options? #2706284
10/12/19 10:20 PM
10/12/19 10:20 PM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
Has anyone come up with a solution to replace the volts reg at the rear of the 66/67 B Body instrument panel?
Ive just blown my second one due to a faulty engine bay reg which sent 18 volts to the panel....and of course it took out my fuel and temp gauges as well. rolleyes
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Instrument voltage regulator options? [Re: Moparmal] #2706287
10/12/19 10:49 PM
10/12/19 10:49 PM
Andrewh Offline
Andrewh  Offline
I built this one
http://www.moparts.org/Tech/Archive/elec/11.html
it works and isn't that expensive.
there is one made by a company for around 25 bucks.
I think this one cost me 4 bucks in parts.
I am not sure it would survive 18 volts either though.
also be sure the gauges are dead. tie 2 AA batteries together serially and apply them to the gauges.
if they move (and it takes a second before they move) they will only go to the middle and you will know they are ok.
Re: Instrument voltage regulator options? [Re: Moparmal] #2706352
10/13/19 09:59 AM
10/13/19 09:59 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Real Time Engineering has them. And theirs are designed that if they fail they fail open, so no voltage .
