np 219 swap bw 300? #2705762
10/11/19 02:22 AM
10/11/19 02:22 AM
kelowna
Darrol Offline OP
Darrol  Offline OP
kelowna
80 j10. 360ci. comes with np 219. looking to swap it out with something better possibly bw 300. or should i just stick with what came from factory? how much better are the bw 300?
Re: np 219 swap bw 300? [Re: Darrol] #2706030
10/11/19 08:26 PM
10/11/19 08:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Darrol, an 80 J10 360 motor is an AMC (American Motors Corp.) motor, not a Mopar 360. Nothing between the two will interchange. The AMC 360 was a good motor, but I suspect some parts may be tough to find.
As far as the transfer case is concerned, I would stick with what was originally there. During that time AMC was buying many major parts from several manufacturers, as a result of this many AMC parts may fit only a year or two, or a specific trans, or rear end, or whatever. Swapping stuff through AMC will become a basket of worms real quickly, few really knew what interchanged, and finding that accurate info these days may be a real challenge.
As an example, back 20 tears ago I bought a pair of J10 Jeeps, one was a heavy duty 78 and the other was an 80. There were no parts that interchanged, except the snow plow brackets I moved from the clapped out 78 to the clean 80 body. The 78 had an AMC 360, but 80 had an unknown V8. The 79 had a GM trans, the 80 had a 727. The front driveshaft on the 78 was on one side of the trans, but the 80 was on the other side, so the transfer cases didn't interchange, front axles did not interchange, transmissions did not interchange, the exhaust did not interchange, and neither did the radiators. I ended up putting a 318 in the 80, and it was a major challenge for me at the time. I sold both J 10 a few months later (less the plow). Don't miss either one. Gene
Re: np 219 swap bw 300? [Re: poorboy] #2706112
10/12/19 07:40 AM
10/12/19 07:40 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
1980 was a major change over year, the front axle went from passenger side diff to driver side. Automatic went from turbo 400 to 727. Transfer case went from Borg Warner to new process.
The 300 is a no go, unless you swap front axle too.
There's several np cases that will swap with driveshaft mods. 208 is the easiest since it was offered originally. Could also be possible to use the 231 and 241.
What's wrong with your 219?
Angry white pureblood male
Re: np 219 swap bw 300? [Re: poorboy] #2706852
10/14/19 10:32 PM
10/14/19 10:32 PM
kelowna
Darrol Offline OP
Darrol  Offline OP
kelowna
Well thank you Poor boy. it sounds like just keeping this jeep the way it is is going to be the smartest thing to do. thanks again.
Re: np 219 swap bw 300? [Re: ruderunner] #2706858
10/14/19 10:46 PM
10/14/19 10:46 PM
kelowna
Darrol Offline OP
Darrol  Offline OP
kelowna
The 219 is getting old.. leaking. nothing terribly wrong . I have it out doing some transmission work and was looking to upgrade is all. thanks for the info. I like my dana front axle its going to stay... along with the rebuilt 219 i guess.
