1939 Dodge D11 front end/brakes and many other questions #2705307
10/09/19 09:16 PM
10/09/19 09:16 PM
Ohio
Rachel4291 Offline OP
Ohio
Hello all,
I am new to the forum, what brings me here today is the new purchase of a beautiful 39 dodge D11. So far it seems to be in fairly decent shape. It has its problems as all older vehicles go. It has a 318 and a 727 transmission, the rear end out of a 70s dodge model and potentially the chassis of a 70 dodge vehicle.
Anyway, what I am having the biggest issue with is finding parts and compatible swaps if parts aren’t available. This has been very cumbersome, I have found several forums wanting to turn the 39 into a rat rod. Nothing against rad rods, but Ive always understood rat rods as being a bit of a Frankenstein car, a piece from this manufacturer and a piece from that manufacture. The previous owner took the time to swap all the old stuff for newer Mopar keeping it true to its origins, which I can appreciate, so we would like to do the same.
Our biggest problem we are facing now are the brakes. When I bought the car I told ahead of time that the brakes did not work and they were unaware of what the issue could be, oh the naïveté of me, I thought the brakes may have been updated at some point in the last 40ish years and a simple swap with new parts and everything would be great. Sadly, this was not the case. The original wheel cylinder was rebuilt on the drive side due to a leak. After bleeding all the brakes there is still very little brake and what appear to be no signs of leaking. I read on another forum that there is an adjustment for the brakes and we have yet to try it but will very soon. All this leads me to my question.
We decided that maybe it would be best to upgrade the brakes to discs, but it would require all these pieces for a front end and this is proving very costly for a fix we are unsure will even work. We had been told that the duster, dart and several other cars from the 70s can fit the front end of the 39 dodge d11. However; this is from a parts lists based on parts needed for conversion kit and one man at an oreillys store. Has anyone had experience putting a front end suspension with disc brakes on these cars? If so what is a compatible swap, is there any extensive cutting or welding required to for the swap, we are not knowledgeable welders by any means.
Any help is greatly appreciated and anything anyone has about upgrades to these cars bearing in mind price would be wonderful!
Thanks in advance.
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: Rachel4291] #2705313
10/09/19 09:25 PM
10/09/19 09:25 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
No need to swap in another front suspension.
http://rustyhope.com/site/mopar-discbrakes/
there area a couple possible options as to what spindles you may have, he details the differences and has kits for them all.
I would suggest you also consider an upper shock mount relocation as the stock setup is ineffectual.
I have had a 38 Plymouth, 40 Chrysler and am now daily driving a 51 Plymouth.
Good luck.
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: Sniper] #2705354
10/09/19 11:49 PM
10/09/19 11:49 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Rusty Hope has a pretty good kit, he supplies the caliper brackets, the bearing spacers, and a couple other things, but most important is a list of the parts you need, so you can buy the parts at your choice of parts stores. I've used several of his kits. There are other disc brake conversion companies that also have very good conversion kits, but most of those are expensive because all the parts you need come with the kits. Be weary of kits that don't use "off the shelf parts" because that means some of the parts may only be available through the kit manufacturer.
What bothers me most was your thought that maybe your car has a 70s chassis swap. You really need to determine if you still have the original front suspension before you can move forward. The original front suspension is pretty unique, a google search will probably provide pictures of the original suspension, it shouldn't be hard to determine if what you have is era correct, the 39 suspension was used up until the early 50s largely unchanged. Gene
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: poorboy] #2705436
10/10/19 09:18 AM
10/10/19 09:18 AM
Ohio
Ohio
Thank you both for the information. I will check them out hopefully make life a lot easier in the brakes. We are basing suspension completely of what it looks like in comparison to the rest of the car, although in very good shape for its age. The suspension itself appears in much better condition than the body. I did search on line for locations of vin number on the suspension. Going to look today.
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: Rachel4291] #2705459
10/10/19 10:11 AM
10/10/19 10:11 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
A picture of front and rear will help us , we can figure out what you have
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: bigdad] #2705481
10/10/19 11:03 AM
10/10/19 11:03 AM
Ohio
Ohio
I am not sure what you might need. I took one of each side and one down the middle.
825F8631-94C8-466F-A0AE-3CBE9529105A.jpegDB667023-DDED-4192-B9D9-049664617FA7.jpeg6E92FEFB-835D-41EB-9DC4-EF7091694E67.jpeg
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: bigdad] #2705496
10/10/19 11:54 AM
10/10/19 11:54 AM
Ohio
Ohio
I missed rear end. Here is that.
If you need better pictures please let me know. I have a general idea of what you need, but not exactly what you need.
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: Rachel4291] #2705550
10/10/19 02:33 PM
10/10/19 02:33 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Front stuff all looks stock ( I though it may have had been changed ) --with exception of the coil springs , they do make parts to interchange the brake/ front end parts
I had one of those kits at one point but, gave it to another guy --I don't think he ever used it however .. I clipped my Desoto --it was a lot of work
the interchange they are takling about is putting a volare front on I'm sure ..that is again a bunch of work and fab skills and tools
this is a guide for your rear you have in the ca --see pic
disc brake parts for the stock 39 front
https://scarebird.com/index.php?route=product/product&path=64&product_id=96
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: bigdad] #2705553
10/10/19 02:41 PM
10/10/19 02:41 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Page 17 on this catalog, will show you can purchase dropped uprights and spindles for about $500 if you want car to sit lower
http://www.fatmanfab.com/wp-content/uploads/2019/07/2019-Fat-Man-Catalog.pdf
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: bigdad] #2705555
10/10/19 02:46 PM
10/10/19 02:46 PM
Ohio
Ohio
Based of what you’ve said. The important pieces for a disc upgrade are original. And if I understand the website as well, there is no adapting or changing of anything it is a bolt of to what I have now, which is very convenient.
Thank you for the help!!
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: bigdad] #2705558
10/10/19 02:48 PM
10/10/19 02:48 PM
Ohio
Ohio
It would look super slick sitting a little lower, but I wonder if that would take some work to the rear fenders. Currently the rear tires are larger than what may have come with the car. Already the fenders are a little tight.
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: Rachel4291] #2705561
10/10/19 02:59 PM
10/10/19 02:59 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I don't have pictures of my Desoto on this computer , if I remember I will post them this evening when I get home, its lowered a lot and I have 225/15's on it or did I should say , I sold it
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: bigdad] #2705562
10/10/19 03:02 PM
10/10/19 03:02 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The scarebird brakes are a somewhat bolt on, you will still have to do some engineering , brake lines getting a new brake master cylinder fit up, etc
more info on that
https://butchscoolstuff.com/brake-boosters-master-cyl-disc-brake-conv-kits/
It will low mount under the floor of the car
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: bigdad] #2705572
10/10/19 03:22 PM
10/10/19 03:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I would run as far and as fast as possible from Scarebird stuff. Just google it.
Butch uses a GM master cylinder that works for virtually no one, you can find several recent threads right here on Moparts about it.
I would mimic a Mopar brake system. You already have the rear end, looks like a 7 1/4. Pull the wheels and see what size the drums are. take a pic of the brake setup and we can tell you what you have.
On the front I would use the Rusty Hope kit that has a decent rep. If you care to roll your own here's an interesting link. Those guys are also familiar with both the Scarebird stuff and Butch's too.
http://p15-d24.com/topic/28870-front-disk-conversion-project/#comments
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: bigdad] #2705598
10/10/19 03:58 PM
10/10/19 03:58 PM
E
earlymopar Online content
earlymopar  Online Content
E
Yes, Butch's also has the brake conversion parts too as well as a reference to purchased parts needed.
- EM
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: earlymopar] #2705634
10/10/19 05:39 PM
10/10/19 05:39 PM
Ohio
Ohio
Thank you all for the tremendous information, just knowing what the car is sitting on has been a huge help and a better understanding of what we can do to the car. I love these old cars, and have since I was young, I was determine to own one one day and I was fortunate to be able to so. But for me it is very overwhelming in terms of what needs to be done and what can be done. I am very limited on my knowledge on working on cars, but hope to learn more with this very intensive project. My boyfriend is the brains behind the operation and the one doing all the heavy lifting so to speak.
Edit:: I do have one more question regarding the brakes (I think). Our intent with the brakes was to fix the brakes if we could then upgrade to a disc brake system over the winter. We just found out that, drum brakes are terrible. Our biggest city is about 30-40 minutes away via the highway and we were told because they brakes do not self adjust we would not make it there without having to adjust the brakes. The reason I am asking, maybe it would be more cost effective to dive into this conversion versus buying odds and ends to fix the drums and not have the ability to drive more than 20 miles at a time without having to make adjustments to the brakes. Would this be the case with the current brake drums?
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: Rachel4291] #2705650
10/10/19 06:32 PM
10/10/19 06:32 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I don't know who is advising you about needing to adjust the brakes that often, they are wrong.
You need to get a copy of the factory serviced manual. RockAuto has it on CD for $20. that will give you the proper procedures and intervals.
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: Sniper] #2705655
10/10/19 06:43 PM
10/10/19 06:43 PM
Ohio
Ohio
A friend of a friend who owns an old vehicle. Thank you, this puts our minds at ease.
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: Rachel4291] #2705678
10/10/19 08:15 PM
10/10/19 08:15 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
One thing that does need to be understood is that these older vehicle do have more stringent maintenance requirements. Especially lubrication intervals. See attached chart
Re: 1939 Dodge D11 front end/brakes and many other questions [Re: Sniper] #2705679
10/10/19 08:16 PM
10/10/19 08:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Minor brake adjustment, I tend to do this every oil change, it's simple enough. See attached. It;s from the same era Plymouth manual, sorry I'm a Plymouth man.
