Front cover heater hose delete? #2705209
10/09/19 03:11 PM
10/09/19 03:11 PM
Columbus, OH
65Dodge440 Offline OP
Columbus, OH
What are people doing with the heater hose holes in their car front timing covers IF you are not running heater hoses? I have a new car cover for a 2016 5.7 Hemi and the holes are not threaded. I eventually plan to add Vintage Air to the car, so maybe I should tap the holes and put pipe plugs in for now? Any simpler better ideas? Thanks!
Re: Front cover heater hose delete? [Re: 65Dodge440] #2705228
10/09/19 04:51 PM
10/09/19 04:51 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Press in freeze type plugs an option?
Re: Front cover heater hose delete? [Re: John Brown] #2705302
10/09/19 08:56 PM
10/09/19 08:56 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I tapped them and put pipe plugs in been fine for 4 years
Re: Front cover heater hose delete? [Re: 65Dodge440] #2705527
10/10/19 01:13 PM
10/10/19 01:13 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Tap and Plug here also
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Front cover heater hose delete? [Re: 65Dodge440] #2705582
10/10/19 03:39 PM
10/10/19 03:39 PM
Northern California
B5 Classic Offline
B5 Classic  Offline
Northern California
Pipe plugs would work fine, but I would put freeze plugs in with a little Permatex sealer. Much cleaner for the discretionary eye and you can always get them out later for stock water pipes if you decide you want a heater.
Re: Front cover heater hose delete? [Re: B5 Classic] #2705976
10/11/19 05:13 PM
10/11/19 05:13 PM
K
Kiddart Offline
Kiddart  Offline
K
Pics???
Thank you
Kiddart
Re: Front cover heater hose delete? [Re: Kiddart] #2709101
10/22/19 08:54 AM
10/22/19 08:54 AM
Springboro, Ohio
Hollywood Offline
Hollywood  Offline
Springboro, Ohio
Dorman 555-011 freeze plug works great.
Re: Front cover heater hose delete? [Re: Hollywood] #2709117
10/22/19 09:43 AM
10/22/19 09:43 AM
Springtown Pa
Springtown Pa
I like that
1996 Viper GTS
Re: Front cover heater hose delete? [Re: Ray408G3Hemi] #2709182
10/22/19 01:04 PM
10/22/19 01:04 PM
Columbus, OH
Columbus, OH
I like Hollywoods freeze plug too. I was convinced I was going with a threaded plug, now I might get little freeze plugs. Either way though, thanks everyone for the ideas.
Re: Front cover heater hose delete? [Re: 65Dodge440] #2709186
10/22/19 01:08 PM
10/22/19 01:08 PM
K
Kiddart Offline
Kiddart  Offline
K
Awesome Thank you!!!
Thank you
Kiddart
