Powder coat motor plate?
#2704840
10/08/19 11:55 AM
10/08/19 11:55 AM
Posts: 625 Indianapolis In. usa
Quickrunner
Any one done this? Any issues with sealing? Powder coat cracking around bolt holes?
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Powder coat motor plate?
[Re: Quickrunner]
#2704841
10/08/19 11:58 AM
10/08/19 11:58 AM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I polished and then clear powder coated mine. I had a heck of a time getting it to seal up after. Ended up using the gasket as a template and then ground away the powder coat so sealant had something to stick to.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: 451Guy]
#2704843
10/08/19 12:08 PM
10/08/19 12:08 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Never had an issue with sealing or cracking with powder coating a motorplate. We do it all the time, just looks better. We also have anodized them with zero issues.
[Re: Al_Alguire]
#2704858
10/08/19 01:11 PM
10/08/19 01:11 PM
Quickrunner
I was thinking anodize would seal better, but everything will match with the powder.
[Re: Quickrunner]
#2704866
10/08/19 01:36 PM
10/08/19 01:36 PM
Posts: 10,022 MN
JERICOGTX
MN
Mine is powdercoated. So far, zero issues.
69 GTX
68 Road Runner
[Re: Quickrunner]
#2704877
10/08/19 02:44 PM
10/08/19 02:44 PM
Posts: 2,916 A shed in England
Tig
A shed in England
After powder coating, we couldn't get the water pump housing to seal for any length of time. It also cracked the powder coat around the mounting brackets , chipped on the edges when we dropped stuff like spanners and vac pumps on it. Looked scruffy after a while. Just have a polished one now.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Quickrunner]
#2704881
10/08/19 02:51 PM
10/08/19 02:51 PM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
Mine is powdercoated...no problems.
[Re: bigdad]
#2705549
10/10/19 02:30 PM
10/10/19 02:30 PM
an8sec70cuda
Ultra Grey silicone works for me.
[Re: an8sec70cuda]
#2705716
10/10/19 09:51 PM
10/10/19 09:51 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've never felt that powder coating was a fits-em-all coating solution. Not a big fan of it in race car applications depending on what the part is and what it does. Other coating processes make more sense.
[Re: CMcAllister]
#2705862
10/11/19 11:42 AM
10/11/19 11:42 AM
Al_Alguire
Las Vegas
Just dropped off dragster motor plate yesterday to get done. Oh yeah valve covers and valley plate too.
[Re: challenger451ci]
#2706223
10/12/19 03:13 PM
10/12/19 03:13 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Both my mid plate and front motor plate where black anodized when I got the car, I talked to a older tech from Power master this morning( he was catching up on tech calls )that I had left a message from this past Thursday about what size(gauge) wire to use on my car with one of their 100 amp single wire after burning up the single #10 I had used originally by accidently grounding out the charging lug on the alternator at the Mopar race at Sacramento last month He said to use a #4 cable directly to the battery and make sure and use a #4 ground from the threaded grounding hole in the alternator back to a threaded hole the engine block to ground the alternator do to the anodizing being a insulator and a bad conductor for the ground from the alternator I'm going to do that this winter to see if I can get rid of some ignition gremlins I've had with this car
[Re: Uberpube]
#2706263
10/12/19 08:21 PM
10/12/19 08:21 PM
Cab_Burge
One pretty famous tuner there also swears that painted motors run hotter according to what he saw on his engine dyno. Years ago, early to mid 1970s, I use to see a lot of NHRA Modified Production racers with bare heads and blocks, some Super Stock cars from east of the Rockies Mountains also Depending on the type and viscosity of the paint will determine how god or bad it seals up the cast iron and aluminum I had one TM7 intake and one set of cast aluminum BB valve covers powder coated black, they ran so dang hot and wouldn't cool down quickly I never did that again That black plastic powder coating really held the heat in those parts, NOT GOOD
[Re: Cab_Burge]
#2706395
10/13/19 01:12 PM
10/13/19 01:12 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Again, I'm not a fan of powder on race car parts.
I wouldn't use it on engine parts. I paint iron blocks, for appearance and rust concerns, but I don't go crazy with it.
For everything else, you spend the time to make stuff fit nice, keep your tolerances tight, fasteners fit the holes, rod ends fit in brackets, assemblies fit mounts. Then put a thick coating of powder on stuff and nothing fits, So you grind, drill, ream, etc., to fix grounds, fits, tight holes, etc. It's OK for some things, but most of this stuff I prefer paint or nothing.
