Re: Front wheel hub 69 roadrunner
[Re: VITC_GTX]
#2704774
10/08/19 07:58 AM
10/08/19 07:58 AM
Posts: 601 Mass
charge70
Mass
Just bought a '69 roadrunner and it quickly developed a bad clunking sound that you could hear/feel in the front end. I found the front left bearing loose so I correctly adjusted it. Twenty miles later is started again so I re-adjusted it again but the noise, again, returned. I took the hub off and the bearings look great but the outer race was loose in the hub (I removed it by hand, it had about .010" slop). The wheel hub doesn't look damaged (e.g. spun race) but the bearing/race are correct for the car. So I started looking to purchase a new wheel hub (drum brakes) but I don't see that anyone sells them.
Anyone else run in to this problem?
Does anyone sell hubs? Does the car have 10" or 11" brakes? The hubs are different.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: 1969RR]
#2704818
10/08/19 10:52 AM
10/08/19 10:52 AM
Posts: 19,555 north of coder
moparx
i was going to suggest the "dimple" trick as well. i have done this countless times on bearing races for applications ranging from automotive use, farm equipment, and machine tools, plus everything in between. extremely few failures over the years doing this. i also use a couple of drops of green loctite, depending on the application.
[Re: moparx]
#2704825
10/08/19 11:11 AM
10/08/19 11:11 AM
Posts: 4,930 Tri-Cities, Washington
VITC_GTX
It has 11" drums.
I did drop the new race in and it was the same way.
I was considering dimpling the surface but I'm not sure that would be enough, maybe.
I haven't talked to a machine shop about putting a sleeve in it. For some reason when I try to get "fancy" like that it blows up in my face. Can't seem to get what I ask for from the shops around here.
I can't believe I can't find a new one anywhere. I've tried local parts stores, rockauto, Classic industries, Year One, etc. Do any of you know of a source?
[Re: VITC_GTX]
#2704994
10/08/19 09:58 PM
10/08/19 09:58 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
So, couple of dumb questions:
1: I'm not convinced that dimpling the hub will make the race tight. How tight does it have to be???
2: How do you remove the brake drum from the hub? I left it soaking in penetrating oil but still can't break it loose by tapping it with a brass hammer. The studs are swedged in locking the drum to the hub. They need to be pressed out first. Unless you hub is super worn a sharp [censored] punch and dimple it all over the press area. Red locktite the race and drive it in. What do you have to lose?
[Re: NITROUSN]
#2705182
10/09/19 01:46 PM
10/09/19 01:46 PM
VITC_GTX
2: How do you remove the brake drum from the hub? I left it soaking in penetrating oil but still can't break it loose by tapping it with a brass hammer. The studs are swedged in locking the drum to the hub. They need to be pressed out first. Unless you hub is super worn a sharp [censored] punch and dimple it all over the press area. Red locktite the race and drive it in. What do you have to lose? Thanks for the information on how the hubs are put together. I’m with you on the dimpling, I’ll try that next week after I get back from hunting.
[Re: VITC_GTX]
#2705495
10/10/19 11:52 AM
10/10/19 11:52 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
It would be nice if you had a picture of your dimpling attempt.If the race was still wobbling, the dimpling did not have the required effect. The race needed to fit solidly in the hub with no wobble. then clean it well, loctite it and let it sit 24 hours before installing. A buddy of mine had the same issue, and the properly performed dimpling method worked well for him.
There is not a lot of meat there to machine and sleeve it, but that sounds like your next step. Or throw a set of police/taxi rotors on there and enjoy disc brakes.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2705501
10/10/19 12:06 PM
10/10/19 12:06 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I tighten the hell out of the nut I must be missing something here. What nut are you talking about? The spindle nut? You can't "tighten the hell out of" that nut. It sets the bearing preload. Are you using a castle washer and cotter pin? Sorry, but something doesn't sound right.
[Re: burdar]
#2705742
10/11/19 12:12 AM
10/11/19 12:12 AM
VITC_GTX
I tighten the hell out of the nut I must be missing something here. What nut are you talking about? The spindle nut? You can't "tighten the hell out of" that nut. It sets the bearing preload. Are you using a castle washer and cotter pin? Sorry, but something doesn't sound right. Yeah, I'm talking about the spindle nut. I was saying that when I put the hub on I spun the hub and tightened the spindle nut really tight prior to backing it off. The manual says to tighten to 90 inch pounds while spinning, I tightened it by hand to over 30-40 lb pounds prior to backing it of. I wanted to make sure everything was seated.
[Re: jbc426]
#2705745
10/11/19 12:15 AM
10/11/19 12:15 AM
VITC_GTX
There is not a lot of meat there to machine and sleeve it, but that sounds like your next step. Or throw a set of police/taxi rotors on there and enjoy disc brakes. I didn't take a picture. I placed fairly deep dimples in the area that the race was sitting. When I was putting it back together I noticed that the hub was probably closer to .020" larger than the race ( I originally thought it was ~.010"). After dimpling the race was moving side to side but was able to spin in the hub. A disc brake conversion may just be easier...
