3.6 PCV ....holy crap! #2704674
10/07/19 07:05 PM
10/07/19 07:05 PM
Kirkland, Washington
Pacnorthcuda Offline OP
I’m doing a oil cooler replacement on a 2012 Wrangler 3.6. Figured I would change the pcv while in there.
Has anyone done this???
It’s on the back side of the passenger valve cover, along with the trans fill tube, main wiring harness, and fuel tank evap line. Even if you removed these I’m not sure it’s possible.
I have the drive bit ratchet...low profile. No help. Can’t get it on either of the two bolts. #25 Torx. Access from below would be a possibility except for the cat. Figured oh well, pop the valve cover, install the pcv then reinstall, but no, the pcv rides around the back of the exhaust cam, so that’s not an option.
Am I missing something? On a transverse minivan this would be easy. This ain’t easy!
Re: 3.6 PCV ....holy crap! [Re: Pacnorthcuda] #2704675
10/07/19 07:10 PM
10/07/19 07:10 PM
PA
70Duster Offline
70Duster  Offline
PA
This might fit under the category, If it ain't broke, don't fix it.
Re: 3.6 PCV ....holy crap! [Re: 70Duster] #2704678
10/07/19 07:29 PM
10/07/19 07:29 PM
Yeah, I’m starting to look at it that way. It’s actually a scheduled maintenance item...every 72k or 100k, not sure.
It’s starting took like a “don’t even think about it unless you are removing the passenger side cat”.
Re: 3.6 PCV ....holy crap! [Re: 3hundred] #2704700
10/07/19 08:46 PM
10/07/19 08:46 PM
You had your rocker arms replaced on a DOHC? Where did they put them?
Re: 3.6 PCV ....holy crap! [Re: Pacnorthcuda] #2704724
10/07/19 09:48 PM
10/07/19 09:48 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I fixed my wrangler problems by lifting the radiator cap and installing a new 2105 jeep with the 3.8, much better jeep IMHO
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 3.6 PCV ....holy crap! [Re: astjp2] #2704746
10/08/19 12:30 AM
10/08/19 12:30 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Factory time is .3 hr .Very poor engineering , that pcv has to be removed to get VC off also .
Re: 3.6 PCV ....holy crap! [Re: astjp2] #2704935
10/08/19 06:33 PM
10/08/19 06:33 PM
Guitar Jones Offline
Dang, Pics or it didn't happen!!
Re: 3.6 PCV ....holy crap! [Re: Pacnorthcuda] #2704999
10/08/19 10:06 PM
10/08/19 10:06 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Mo' Farts
Moderated by "tbagger".
Re: 3.6 PCV ....holy crap! [Re: Guitar Jones] #2705009
10/08/19 10:39 PM
10/08/19 10:39 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I've been looking for a vehicle lately, looked from late 90s to 2018, why do you think that I have settled on finding an 80s D/W truck from the south and having it shipped up here while I run my 96 Dakota for winter? I work on newer crap all day and don't want any of that headache for myself. Give me simple, carbureted, mechanical fuel pump, wing windows, dimmer switch on the floor. Screw electronics, excess plastic, and "global assembly".
