3.6 PCV ....holy crap!
#2704674
10/07/19 07:05 PM
10/07/19 07:05 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
I’m doing a oil cooler replacement on a 2012 Wrangler 3.6. Figured I would change the pcv while in there.
Has anyone done this???
It’s on the back side of the passenger valve cover, along with the trans fill tube, main wiring harness, and fuel tank evap line. Even if you removed these I’m not sure it’s possible.
I have the drive bit ratchet...low profile. No help. Can’t get it on either of the two bolts. #25 Torx. Access from below would be a possibility except for the cat. Figured oh well, pop the valve cover, install the pcv then reinstall, but no, the pcv rides around the back of the exhaust cam, so that’s not an option.
Am I missing something? On a transverse minivan this would be easy. This ain’t easy!
Re: 3.6 PCV ....holy crap!
[Re: 70Duster]
#2704678
10/07/19 07:29 PM
10/07/19 07:29 PM
Pacnorthcuda
This might fit under the category, If it ain't broke, don't fix it. Yeah, I’m starting to look at it that way. It’s actually a scheduled maintenance item...every 72k or 100k, not sure. It’s starting took like a “don’t even think about it unless you are removing the passenger side cat”.
[Re: Pacnorthcuda]
#2704724
10/07/19 09:48 PM
10/07/19 09:48 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I fixed my wrangler problems by lifting the radiator cap and installing a new 2105 jeep with the 3.8, much better jeep IMHO
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2704935
10/08/19 06:33 PM
10/08/19 06:33 PM
Guitar Jones
I fixed my wrangler problems by lifting the radiator cap and installing a new 2105 jeep with the 3.8, much better jeep IMHO Dang, Pics or it didn't happen!!
[Re: Guitar Jones]
#2705009
10/08/19 10:39 PM
10/08/19 10:39 PM
Posts: 2,250 ILLINOIS
volaredon
ILLINOIS
I've been looking for a vehicle lately, looked from late 90s to 2018, why do you think that I have settled on finding an 80s D/W truck from the south and having it shipped up here while I run my 96 Dakota for winter? I work on newer crap all day and don't want any of that headache for myself. Give me simple, carbureted, mechanical fuel pump, wing windows, dimmer switch on the floor. Screw electronics, excess plastic, and "global assembly".
