Do you use offset lifters with you 440 -1 heads?
#2704515
10/07/19 10:04 AM
10/07/19 10:04 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I see a few offset options listed for use with -1 heads. Research dictates some use .180, some use .210 and others use no offset. Any -1 owners care to share? @dvw @HardcoreB
Ps infolinks blows @moparts
Tom you are going to force me to facebook...
Re: Do you use offset lifters with you 440 -1 heads?
[Re: Jeremiah]
#2704523
10/07/19 10:20 AM
10/07/19 10:20 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have both Harland Sharp and T&D rockers but it’s been so long since I’ve run those heads I honestly forget what they are. But I’m sure it’s listed on their website
I may be putting together a 512 mega block build with my 440-1 heads and a 1150 alcohol carb over the winter
[Re: BradH]
#2704558
10/07/19 11:45 AM
10/07/19 11:45 AM
Jeremiah
Rogue River, OR
PBR - I have a set of 1.7 Jesel paired rockers so that is already set in stone.
FastMop-Thanks for the info IIRC that is a tall deck? What RPM do you spin it to?
B-rad: I appreciate the info on the .210 BAM lifters. I think that is what Mike Jones sells and I am looking hard at the steel on steel bushing option. Being a low deck I have better get the heads back and mock everything up. FWIW I used Isky .180 offset on the intakes of my Victor motor and it helped the p/rod angles significantly.
Another stupid question - With p/rod oiling (Jesel paired blocks feed from block) can I run a solid body lifter or do I need the oil band? If so how do I know which lifter won't uncover the band at full lift? My first guess is that I will have to get specs on the prospective lifters and compare them to the cam lift.
[Re: Jeremiah]
#2704572
10/07/19 01:09 PM
10/07/19 01:09 PM
Posts: 31,050 Oregon
AndyF
Another stupid question - With p/rod oiling (Jesel paired blocks feed from block) can I run a solid body lifter or do I need the oil band? If so how do I know which lifter won't uncover the band at full lift? My first guess is that I will have to get specs on the prospective lifters and compare them to the cam lift. Might be smart to buy one pair of lifters and mock things up before you buy the complete set.
[Re: Jeremiah]
#2704575
10/07/19 01:15 PM
10/07/19 01:15 PM
Posts: 43,227 Bend,OR USA
Cab_Burge
[Re: Jeremiah]
#2704576
10/07/19 01:15 PM
10/07/19 01:15 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Another stupid question - With p/rod oiling (Jesel paired blocks feed from block) can I run a solid body lifter or do I need the oil band? If so how do I know which lifter won't uncover the band at full lift? My first guess is that I will have to get specs on the prospective lifters and compare them to the cam lift. Sorry I misread your post. For some reason this is the only site that when I go to on my phone I need my bifocals.
[Re: Jeremiah]
#2704582
10/07/19 01:30 PM
10/07/19 01:30 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Tom you are going to force me to facebook... Ok this is what I ran into with 440-1 heads. Standard (zero) offset roller lifters worked with my stock blocks (3/3 pushrods) but when back in 2008-2009 I had to buy a set of offset lifters for clearance on my Keith Black block. The shortblock was built and I didn’t want to tear it apart to grind clearance. When I tore it apart the next time I did some valley grinding so this would no longer be an issue. Some of these bigger pushrods cause some clearance issues.
[Re: pittsburghracer]
#2704588
10/07/19 01:40 PM
10/07/19 01:40 PM
BradH
Some pics, in case it helps.
One (the one w/ the notes added) was something I found that Jim Hanrahan (440Jim) posted years ago. Looks like Jim's picture was taken w/ zero-offset lifters, but annotated to show where grinding would be needed to use offset intakes..
The others are from the mock-up I mentioned above. If you look closely at the #3 intake, you can see the masking tape I put on the pushrod is being torn off due to lack of clearance w/ the block boss. The intake pushrods were all really close, even if they didn't rub.
[Re: WedgeFED]
#2704627
10/07/19 04:36 PM
10/07/19 04:36 PM
Posts: 4,209 New York
polyspheric
New York
Remember to limit your comments, search terms, sites visited to what the craziest Democratic candidate would agree with, because Google's file on you (your e-mail, IP address, log-ins), shall we say, is not private and personal?
I like correcting pushrod angularity, but this must be weighed against "does it require a smaller pushrod OD than the other lifter choice"? The usual rule: if you're not sure your pushrod is the largest one that fits... it's too small.
Boffin Emeritus
[Re: Cab_Burge]
#2704647
10/07/19 05:31 PM
10/07/19 05:31 PM
Jeremiah
Rogue River, OR
Interesting. I'll give you call once I know enough to have an intelligent conversation lol. : D
[Re: polyspheric]
#2704648
10/07/19 05:36 PM
10/07/19 05:36 PM
Jeremiah
Rogue River, OR
I like correcting pushrod angularity, but this must be weighed against "does it require a smaller pushrod OD than the other lifter choice"? The usual rule: if you're not sure your pushrod is the largest one that fits... it's too small. Good thoughts on the tapered push rods. I will most certainly watch out for that. On the Google ads subject - Hilarious stuff shows up due to sharing an internet with my wife. When she is shoe shopping I know whats up and when I am looking for car parts (roller lifters) she starts getting ads for Isky and Comp. Funny stuff but yeah I hear you on that front JD.
[Re: BradH]
#2704649
10/07/19 05:37 PM
10/07/19 05:37 PM
Jeremiah
Rogue River, OR
The others are from the mock-up I mentioned above. If you look closely at the #3 intake, you can see the masking tape I put on the pushrod is being torn off due to lack of clearance w/ the block boss. The intake pushrods were all really close, even if they didn't rub. Excellent information, thank you sir! I have a pic of my 511 with the .180's somewhere. Will see if it is in the readily available archives.
[Re: AndyF]
#2704650
10/07/19 05:42 PM
10/07/19 05:42 PM
Jeremiah
Rogue River, OR
Another stupid question - With p/rod oiling (Jesel paired blocks feed from block) can I run a solid body lifter or do I need the oil band? If so how do I know which lifter won't uncover the band at full lift? My first guess is that I will have to get specs on the prospective lifters and compare them to the cam lift. Might be smart to buy one pair of lifters and mock things up before you buy the complete set. 100% spot on. I'd rather spend $100 and know everything is right instead of making compromises due to a hasty decision in the past. This motor needs to make good power as it is going in the grudge/no prep car. After having so much darn fun at the last two events I am wanting to get going for 2020. Might even have some sponsorship $$$ to help with parts we have yet to buy and some fresh tires. AR Engineering sure would look cool on that black car lol. Andy, do you have any single sets of offset roller lifters in your mock up stash?
[Re: FastmOp]
#2704659
10/07/19 06:28 PM
10/07/19 06:28 PM
Posts: 1,229 In The Hills
jughed
In The Hills
0 offset Comp Cams 829-16s work just fine with 440-1s and 1.6 T&Ds. Pushrods are 3/8" Smith Bros.. Mega Block. Been running this 540" combo for 10+ years...zero issues I run straight rollers, Comps.
This site is going down hill fast with the stupid adds What ads?? AdBlock Plus https://adblockplus.org/
[Re: jughed]
#2704697
10/07/19 08:39 PM
10/07/19 08:39 PM
Posts: 183 Casper, WY
Wax
Casper, WY
