67 vs 68 Barracuda #2702456
09/30/19 11:20 PM
09/30/19 11:20 PM
Texas
6pkRB Offline OP
6pkRB  Offline OP
Texas
What is different on the 67 vs 68 barracuda fastback?
I want the 67 I am looking at to look like a 68.
I know the side marker lights will need to be added, the rear backup lights will need to be deleted, the rear taillights are different and the panel between the rear lights is different.
Will the parts be hard to find to convert it over to look like a 68?
This will be a race car, so it does not have to be perfect on the inside, but would like to know the difference in the dash area?
Anyone out there have the parts necessary they would let go to do this?
Thanks for the help.
Re: 67 vs 68 Barracuda [Re: 6pkRB] #2702466
10/01/19 12:12 AM
10/01/19 12:12 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
You might be better of starting with a ‘68. To truly make it look like ‘68 is going to be expensive.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 67 vs 68 Barracuda [Re: BloFish] #2702583
10/01/19 11:47 AM
10/01/19 11:47 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
What I remember (I've had a 67, 68 & 69 years ago) on 67 vs 68 appearance:
Grilles, header panel letters/nameplate
Hood ornamentation
Fender nameplate & location
Windshield seal & moldings
Back glass seal & moldings
Tail lamps, trunk panel
Backup lamps moved into tail lamps & side markers added.
I don't recall the dashes being much different except for 68 had a lower pad added
Interior trim changed yearly.
Not hard to pull off, but a bit spendy...
Re: 67 vs 68 Barracuda [Re: topside] #2702623
10/01/19 01:29 PM
10/01/19 01:29 PM
Texas
6pkRB Offline OP
6pkRB  Offline OP
Texas
Thanks guys.
That was what I was afraid of.
Re: 67 vs 68 Barracuda [Re: 6pkRB] #2702640
10/01/19 02:20 PM
10/01/19 02:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If it is a race car, why add extra weight like marker lights & lower dash pads?
Re: 67 vs 68 Barracuda [Re: Alaskan_TA] #2702652
10/01/19 03:01 PM
10/01/19 03:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
68 tail trim will be pricy
2011 Drag Pak Challenger
Re: 67 vs 68 Barracuda [Re: Alaskan_TA] #2702980
10/02/19 11:25 AM
10/02/19 11:25 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Guessing he wants to run a class that the combination is limited to 1968 bodies. Perhaps he wants to run NHRA GT classes. With a 68 you can run a Hemi scoop. 67 no fresh air.
If he wants to run a 340 in Stock or Super Stock (excepting the GT classes) he would need to run a 68.
So there can be lots of reasons to change the year.
Of course this is assuming it is a race car.
Re: 67 vs 68 Barracuda [Re: 6pkRB] #2702993
10/02/19 11:40 AM
10/02/19 11:40 AM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
I wrote this years ago, based on what I found when trying to swap parts. Some of these things matter (like the grill) and some or more subtle (like the doors/glovebox).
https://board.moparts.org/ubbthread...-between-67-69-barracudas.html#Post50614
Good luck
Re: 67 vs 68 Barracuda [Re: 6T6Cuda] #2703795
10/04/19 12:33 PM
10/04/19 12:33 PM
Texas
6pkRB Offline OP
6pkRB  Offline OP
Texas
Great list on this article.
I see where it could get expensive if you are trying to duplicate a correct car.
Just wanted the outside to resemble a 68.
Will be used as a race car only.
Thanks again.
Re: 67 vs 68 Barracuda [Re: 6pkRB] #2703800
10/04/19 12:47 PM
10/04/19 12:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Heck, in that case it's not a big deal; change the grilles & rear lamps and trunk lid trim, and most folks at the track wouldn't know it's a '67, including Tech.
The more important stuff is how suitable the car is for the drags.
My car in the avatar was run as a '71 during its professional career, but it's actually a '70.
The Hamburger/Bachelder/Chipman Demon was originally a Duster.
There are several cars like that in current Stock, SS, nostalgia, and stock-appearing-musclecar classes, all makes.
