Scratched bore reassembling shortblock
#2703478
10/03/19 04:37 PM
10/03/19 04:37 PM
Posts: 301 central Pa.
71Pan
central Pa.
Number 4 cylinder oil retaining ring scratch cylinder. Pulled piston rehoned gonna try it what do you guys think about .001 deep .Every thing fresh ughhhhh
Re: Scratched bore reassembling shortblock
[Re: krautrock]
#2703493
10/03/19 04:53 PM
10/03/19 04:53 PM
Posts: 147 AZ
squirrel
AZ
[Re: krautrock]
#2703502
10/03/19 05:07 PM
10/03/19 05:07 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
I would agree...scratches usually are straight as a string...cracks not so much
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2703505
10/03/19 05:12 PM
10/03/19 05:12 PM
Posts: 9,525 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Unless you dropped something harder then the bore in it, it does lookie like buttcrack, buttman.
UMMM did you by chance file your own rings?
STOP POTATO HATE!
[Re: DoubleD]
#2703521
10/03/19 05:48 PM
10/03/19 05:48 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I will take your word for it and assume that is not a crack.
It looks like there is some flashing over the edge of the scratch making it appear as a crack though? I can see the skipping of the ring in the gouge after looking close at your picture. I have ran bores that were pitted pretty good but never a long, horizontal wound like that. What kind of ring are you using? Can you hone it another thou and make it go away completely?
How much hp are we talking?
[Re: 71Pan]
#2703542
10/03/19 06:36 PM
10/03/19 06:36 PM
Posts: 43,251 Bend,OR USA
Cab_Burge
It looks like a crack to me, you can use heat to make sure. I've used heat guns, hair dryers, propane torches to help identify cracks in cast iron, apply heat and watch closely to see if it moves, grows or change how it looks Way better to find out now before reassembling it BTW, if it was sticking above the cylinder wall, what would cause that It should have flatten out with the honing unless you use a dingle berry hone
[Re: 71Pan]
#2703619
10/03/19 10:37 PM
10/03/19 10:37 PM
Cab_Burge
The block sonic tested well over .200 in that area don't know how I would .have cracked the wall tapping a piston in. No way in the world that you could have caused that crack, NO WAY I've assembled more than one motor, I see straight scratches in the new honed cylinder a lot from me not getting the file to fit ring ends smooth enough to not scratch the cylinder walls, none of them have ever looked like your does s Me thinks your shop did not mag that cylinder wall, take it back and have them look at it now to be safe I've had several good auto Hi Po machine shops in SO CA miss external cracks on several different 906 heads that where cracked under the exhaust ports, most shops do a lot more other brands than BB Mopars and neither one was aware that those freeze cracks are not uncommon on 906 heads
