Re: Swapping 727's
[Re: Garry Owen]
#2702221
09/30/19 11:04 AM
09/30/19 11:04 AM
RapidRobert
The imbalance IS in the converter rather than the flexplate so you would use the old/orig conveter. Flexplates should be indentical
Re: Swapping 727's
[Re: RapidRobert]
#2702348
09/30/19 07:02 PM
09/30/19 07:02 PM
Garry Owen
The imbalance IS in the converter rather than the flexplate so you would use the old/orig conveter. Flexplates should be indentical What about this Flexplate
Re: Swapping 727's
[Re: Garry Owen]
#2702590
10/01/19 12:09 PM
10/01/19 12:09 PM
RapidRobert
^^^ that'll take care of it also. & if you pull the converter I would replace the front pump seal & take care with it as you dont want to have to pull the whole shebang back out of there again for a leaker & I think they make a driver tool that supports the inside ID of it as you drive it in. I tapped one in by hand carefully & it leaked so on my next one I am gonna source that tool
