Mancini vs Mr. Gasket distributor advance springs
#2701992
09/29/19 01:42 PM
09/29/19 01:42 PM
Posts: 220 Aurora, CO
jbeintherockies
Aurora, CO
Hi, Has anyone on here tried both the Mancini and Mr. Gasket distributor advance springs? I was wondering if there is any difference in spring stiffness between the two. https://www.manciniracing.com/disadweigspr.htmlThe car I am working on has what appears to be a Mopar Performance distributor. https://drive.google.com/file/d/11wCWbwdOc88JX-NO2QipOSd-XHDh5A8M/view?usp=sharingI have read to use one Mr. Gasket spring and one of the springs that comes with the distributor to get my total timing all-in at around 2500 rpm. Right now, it is all-in at about 3000 rpm. I will call Mancini on Monday to see what they suggest. Thank you in advance for the help. Jon
Re: Mancini vs Mr. Gasket distributor advance springs
[Re: jbeintherockies]
#2702021
09/29/19 03:17 PM
09/29/19 03:17 PM
Posts: 953 Badham Co.
Y3 70 BEE
Badham Co.
The Mopar Performance springs are the ones they sold to put in a distributor, they are really light. Removing the heavy spring and just using the stock light spring usually works good for a street car.
#2702045
09/29/19 06:15 PM
09/29/19 06:15 PM
RapidRobert
Can you please explain the table a little bit. Is it suggesting that my advance with the advance springs that come with a Mopar Performance distributor should provide all-in advance by 1100 rpm?
What is "point x" and what is "point y"? X is when the spring or spring combo starts advancing & y is when the particular spring or spring combo reaches full advance. EDIT I forget where I copied the chart from but yes it is sayin the MP combo would be all in at 1100
[Re: RapidRobert]
#2702087
09/29/19 08:43 PM
09/29/19 08:43 PM
Posts: 144 Missouri
randavis
Missouri
Is that chart in distributor degrees or crank degrees. If dist degrees, then crank degrees would be 2200 for the MP springs which is what I seem to remember from the old catalogs.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
#2702088
09/29/19 08:46 PM
09/29/19 08:46 PM
Posts: 12,144 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Our big blocks tend to like the advance all-in as quick as possible as long as it doesn't ping under load. Small blocks tend to be less picky. But you do not want the advance to begin until the RPM is above the idle. If it starts advancing while idling, you will be chasing the idle speed all the time, since the advance will be changing with engine speed especially when dropped in gear if an auto. For a big block, I like to try for advance to start about 1,000RPM and be all-in by 1,500RPM. Then check to be sure that there is no spark knock under 2,500RPM. And the more overlap in the cam, the more advance they like in the idle. Most of my big blocks (and my current Hemi) have 25* to 28* advance at idle. Basically, all I can get before it starts kicking back against the starter.
Master, again and still
[Re: DaveRS23]
#2702090
09/29/19 08:58 PM
09/29/19 08:58 PM
RapidRobert
thats what I was getting ready to comment on is that you dont want the springs to start advancing until several hundred RPM above the idle speed & someone said something about the center hole in the FBO plates to be to big possibly causing a problem (hanging up or inconsistent advance amt I would guess). I have several of em & I am going to check that out & maybe reduce the center hole ID but it is a good deal for the money.
[Re: randavis]
#2706484
10/13/19 08:05 PM
10/13/19 08:05 PM
RapidRobert
Is that chart in distributor degrees or crank degrees. crank
#2706839
10/14/19 09:38 PM
10/14/19 09:38 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
It may be a DC/MP vac advance distributor based on what I can see of the number. If so, its already got a pretty good curve in it. If you're dedicated drag racing, then the vac advance isn't needed and in that case, using a lighter primary spring may be an advantage. You'll then need to be sure there is enough initial tension so the advance is stable at idle speed. Leave the heavy spring installed. That's part of the secret of why the MP/DC distributor are better than most aftermarket. A heavy secondary spring normally is used to slow down advance as the rpms get into better combustion above roughly 2000. But it also is used to offset electronic switching time (slew rate). see https://board.moparts.org/ubbthread...ry-unilite-timing-issue.html#Post2488504If you're not dedicated drag racing, then work with the factory springs - especially if it is a DC/MP distributor. You can tweak the tension on the primary, and the engagement point on the second spring by turning the spring perch. If the advance is really too long - say because a long duration cam is being used, then weld a tack on the inside of the slots. File it and you're done. If its not a MP distributor, depending on the original application you may find a really long advance, like 30*. In which case, weld a tach and file it to length.
#2707198
10/16/19 08:53 AM
10/16/19 08:53 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yeah, with 4.10s, you will probably be able to be all-in much earlier than 3,000 without pinging. In fact, I would try all-in by 2,000.
