Page 129 of 159 1 2 127 128 129 130 131 158 159
Re: Paint job on a budget!? CONTINUED..page 44........ #27018
03/02/07 04:34 PM
03/02/07 04:34 PM
Sanding tip: put masking tape on the edges and ridges of panels before sanding them. Saves much grief.
LanceB
Re: Paint job on a budget!? CONTINUED..page 44........ #27019
03/03/07 02:58 AM
03/03/07 02:58 AM
Kansas
dalbers Offline
dalbers  Offline
Kansas
don't tell them how you painted it until you get all the compliments bob
Re: Paint job on a budget!? CONTINUED..page 44........ #27020
03/03/07 11:21 AM
03/03/07 11:21 AM
Bob D,
Gotta tell ya, loved your website. Seeing all the work you put into that old truck is inspirational. My hat's off to ya. You almost had me wanting one too, until you reminded me of the 9 mpg! LOL
Re: Paint job on a budget!? CONTINUED..page 44........ #27021
03/03/07 11:25 AM
03/03/07 11:25 AM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
I'm going to unstickie this we have so many replie I don't think it needs to be a stickie. I doubt it will fall by the side anytime soon.
Oh took the wife for her first ride in the truck, went to a local recycle place, the workers could not believe I rolled the paint job on.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #27022
03/03/07 01:15 PM
03/03/07 01:15 PM
toronto canada
69chargeryeehaa Offline OP
toronto canada
If the thread dies due to not being a sticky, then it will be a good death , i thought it would die along time ago.
Every time i look at it i'm amazed and really glad i shared this with all you guys, and the results i'm seeing make it all worth it. This has to be the longest thread i've ever seen on any board, i never thought it would go this far and survive the haters.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69chargeryeehaa] #27023
03/03/07 10:58 PM
03/03/07 10:58 PM
I sprayed my speedster black today. I used duplicolor in the gallon can. It isn't rustoleum but is almost as cheap at $33 a gallon. It went on really nice with minimal orange peel. I could live with the slight orange peel in places but I did get some runs that I am going to have to color sand and buff. This was my first real paint job and was surprised how well it came out. The gloss and reflection is unreal. I used the hardener and recommend it if you spray but make sure you wear appropriate protection. I will try to post some pics tomorrow. Thanks charger for the advice.
Scott
Re: Paint job on a budget!? CONTINUED..page 44........ #27024
03/03/07 11:28 PM
03/03/07 11:28 PM
Brightside gurus, what am I doing wrong here? I thinned out the paint at roughly 10%. This was the first coat. Basicall I'm getting tons of orange peal...perhaps it was just way too think of a coat?
I also tried marq's trick of running a spirts soaked roller over it, but it didn't seem to help much
pic 1
pic 2
pic 3
Re: Paint job on a budget!? CONTINUED..page 44........ #27025
03/04/07 02:10 AM
03/04/07 02:10 AM
socal
s4dustin Offline
s4dustin  Offline
socal
ok, tried the first 2 coats on a fender piece i had laying around. cleaned it, cut the rustoleum with mineral spirits, 50-50, rolled on, let stand for 15 min, then rolled it again to get off the bubbles...did the blowing on it trick (yea yea yea) let it dry. An hour later, put on second coat. Stopped there. It sat for about 6 hours and it wont rub off or scratch off with finger nail. Tomorrow, will do the first wet sand and 2 more coats. If it works, i am going to do my 68 camaro this way. I also spoke with a friend who says i should use the marine paint he used on his boat. This guy has painted a couple of hundred cars and says "yeah, you can use a roller, there is no overspray and prep is a lot less"....... here are some pics
panel
lst coat
second coat
it has a nice gloss to it, you can see your reflection in the paint. still need to wet sand and then do coats 3-6
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: s4dustin] #27026
03/04/07 09:14 AM
03/04/07 09:14 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Spyhunter- yes, that is way too thick. Back about 123190283 pages ago I suggested people doing test panels should use a surface that is vertical rather than horizontal like a hood. I think if you tried to put paint that thick on a vertical surface like a door, you would see that it's too thick because it would run like crazy.
Dustin that looks good. I would suggest using some marine paint too..
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #27027
03/04/07 11:11 AM
03/04/07 11:11 AM
So do you think it was simply my application technique or it wasn't thinned enough? I did have a few runs on it
Re: Paint job on a budget!? CONTINUED..page 44........ #27028
03/04/07 11:42 AM
03/04/07 11:42 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I think its the application technique, there shouldn't be any runs when thinned 10%.
Im not sure what others are doing, but what I would do is push most of the paint out of the roller into the tray, and when I was rolling the car I would put a pretty firm pressure. That seemed to work for me to put thin coats on.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #27029
03/04/07 03:39 PM
03/04/07 03:39 PM
Kansas
dalbers Offline
dalbers  Offline
Kansas
Here are some of the hood using brightside after two coats.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: dalbers] #27030
03/04/07 03:39 PM
03/04/07 03:39 PM
Kansas
dalbers Offline
dalbers  Offline
Kansas
another
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: dalbers] #27031
03/04/07 03:40 PM
03/04/07 03:40 PM
Kansas
dalbers Offline
dalbers  Offline
Kansas
another one
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: dalbers] #27032
03/04/07 03:40 PM
03/04/07 03:40 PM
Kansas
dalbers Offline
dalbers  Offline
Kansas
last hood one
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: dalbers] #27033
03/04/07 03:41 PM
03/04/07 03:41 PM
Kansas
dalbers Offline
dalbers  Offline
Kansas
and one of the fender
Re: Paint job on a budget!? CONTINUED..page 44........ #27034
03/04/07 05:21 PM
03/04/07 05:21 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Kind of looks like my first coat, I only thinned to 10% the second and later coats I thinned until after I stirred and picked the stir stick up out of the panit I could count to about 10 then the paint would go from a stream to drops if that makes sense. The paint seemed to lay down better much less orangepeel and no rolls, I had to do a lot of sanding after my forst coat to get it to were I could paint again.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69chargeryeehaa] #27035
03/04/07 05:33 PM
03/04/07 05:33 PM
St Andrews ,Manitoba ,Canada
C38coupe Offline
C38coupe  Offline
Hi all, here is another use for Tremclad and Rustoleum an old body man told me about. Instead of using epoxy primer he has and continues to use Rustoleum primer with automotive enamel reducer to thin it before spraying his work. He now does this before any other work is done, he does it before filler, primer surfacers, top coats etc. He has been doing this for many years, and thinks Tremclad and Rustoleum paints are both great products. He is a professional aircraft painter by trade, he laughs when paint suppliers tell him you can't use "that Rustoleum house paint", on a car. They always tell him it's going to peel off or fall off if you go over it with Automotive enamel or urethane products, of course this is not true, I am not sure about lacquer based products, but I have sprayed rubberized rockerguard coating right over tremclad with no ill effects. I am not sure what rockerguard is based with.
Yesterday I was playing with a HVLP gun and Tremclad paint thinned with just mineral spirits, wow did it ever paint nice, and I could not believe the lack of overspray, the gun is a Princess Auto $50.00 special, worked very nice with Tremclad and it's 1.4 tip.......All the best to everyone keep on rollin
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: C38coupe] #27036
03/04/07 05:53 PM
03/04/07 05:53 PM
socal
s4dustin Offline
s4dustin  Offline
socal
so when i wet sand, how much do i sand it? alot of paint came off. it was pretty smooth, applied coat 3, a little too thin, but coat four will be thicker....
i am going to get marine paint and try it too, hopefully they have deeper, richer blues
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: s4dustin] #27037
03/04/07 08:50 PM
03/04/07 08:50 PM
Here are pics of speedy. I think I will wait a few days and sand the runs and then about a month before I color sand the whole car. I recommend the duplicolor and it says it can be rolled. Here they are.
[IMG]http://img.photobucket.com/albums/v377/swoodard23/DSCI0010_640x4[IMG]
