69 road runner drum brake problem #2701774
09/28/19 04:29 PM
09/28/19 04:29 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
My 69 road runner has developed a problem when you apply the drum brakes it pull to the left.I have changed the brake shoes same result. Now I have changed the wheel bearings and adjusted them evenly ,Drove the car it was ok for awhile. I have not turned the drums could they be glazed?The brake hoses are fairly new ? Any suggestions? thanks for any help
Re: 69 road runner drum brake problem [Re: 3wracing] #2701780
09/28/19 04:46 PM
09/28/19 04:46 PM
GA
roadrunninMark Offline
GA
I would look at the wheel cylinders on the right side. Sounds like the left is working and the right is not, most likely the front right. Did you have to adjust the one side more than the other?
Re: 69 road runner drum brake problem [Re: roadrunninMark] #2701781
09/28/19 04:50 PM
09/28/19 04:50 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
I just adjusted them new brakes I put them on and didn't pay attention. is thiier a way to check now?
Re: 69 road runner drum brake problem [Re: 3wracing] #2701785
09/28/19 05:05 PM
09/28/19 05:05 PM
GA
GA
You can jack the car up and have someone press the brake pedal. See how much resistance on each wheel and if it is a lot different. It should be able to lock up each wheel. If you do not have any resistance, that wheel cylinder is bad. If they are all old, might be worth it to just replace them all. Also, how does the fluid look? Is it gold color, brown, black, or? Possibly if it is real dirty and old, could be clogged up. I think you said you changed all your soft lines? If not, possibly one is bulging when you apply brakes and are loosing pressure to that cylinder.
Re: 69 road runner drum brake problem [Re: roadrunninMark] #2701786
09/28/19 05:08 PM
09/28/19 05:08 PM
GA
GA
Also, if you drove it a lot and the difference of braking continued to get worse over time, did you install the adjusters backwards? This won't allow the shoes to get equally close (side vs. side) to the drums, causing the correct one to contact the drum first, therefore causing it to pull to that side.
Re: 69 road runner drum brake problem [Re: 3wracing] #2701788
09/28/19 05:10 PM
09/28/19 05:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
How old are the flexible hoses?
The internal liners can fail & act like a one way valve, pressure goes in & it does not release as one would normally expect.
Re: 69 road runner drum brake problem [Re: 3wracing] #2701817
09/28/19 07:48 PM
09/28/19 07:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Have you verified the ball joints, tie rods, bushings etc are good??? shruggy beer
Re: 69 road runner drum brake problem [Re: TJP] #2701851
09/28/19 09:28 PM
09/28/19 09:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just checking but did you install the long shoes in the back and the short on the front side?
Re: 69 road runner drum brake problem [Re: stumpy] #2701912
09/29/19 08:38 AM
09/29/19 08:38 AM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
yep shoes installed correctly. the car was lazer lined up the tech said it was never in any crashes not tweaked in any way.
Re: 69 road runner drum brake problem [Re: 3wracing] #2701915
09/29/19 09:53 AM
09/29/19 09:53 AM
As said a pass side issue (it ain't doing any/enough braking force). front wheels off the ground tighten the adjusters till the wheel is locked solid then loosen till you hear a slight "tick" of contact in one point in the tires revolution as you spin the wheel forward by hand. do both LF/RF. If needed might need to do the rears also to get em all even but you wont be turning them forward by hand, idling in gear up on stands & need a helper to hit the brakes to stop it so you can spoon it some more then he releases & repeat till you hear the "tick".
Re: 69 road runner drum brake problem [Re: RapidRobert] #2704705
10/07/19 09:06 PM
10/07/19 09:06 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
check strut rods/bushings
Re: 69 road runner drum brake problem [Re: 3wracing] #2704725
10/07/19 09:49 PM
10/07/19 09:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Make sure both rear wheels are working correctly. Many times on the old 4 wheel drum cars the pulling was from the rear not working correctly. Anything from grease leak , wheel cylinders, adjustments. Problems in the rear will cause a front imbalance and lead to one side.
