Best way to apply wrinkle black paint? #2701637
09/28/19 07:54 AM
09/28/19 07:54 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Looking for input/best practices on applying wrinkle black paint to an air cleaner.
Re: Best way to apply wrinkle black paint? [Re: vinnyd76] #2701644
09/28/19 08:55 AM
09/28/19 08:55 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I bought the Summit brand wrinkle paint in the rattle can and it worked good and stayed on for going onm 5 years now. I just prepped the surface with scotch brite and cleaned with a good surface prep cleaner.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best way to apply wrinkle black paint? [Re: vinnyd76] #2701656
09/28/19 10:14 AM
09/28/19 10:14 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Have it powder coated...
If your spray bombing, apply 3 medium coats, waiting 10 minutes between coats, put in an oven preheated at about 250-300 degrees F to force/cure a good wrinkle, let dry for several days/weeks depending on the brand you use... I've had good luck with VHT brand
Re: Best way to apply wrinkle black paint? [Re: DAYCLONA] #2701716
09/28/19 12:30 PM
09/28/19 12:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Good info above. I also like to pre-heat the part - not too hot to touch, though - and lay down a coat of satin black first.
The reason for the pre-coat/ tack coat is so I don't have to chase a perfect wrinkle coat into a run.
Re: Best way to apply wrinkle black paint? [Re: vinnyd76] #2701717
09/28/19 12:31 PM
09/28/19 12:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
prep the surface
Lay down even coats. Uneven coating = uneven wrinkles
IF possible, Set item over heat source like an oil filled radiant heater, kerosene heater on low to medium etc.
Stand back and watch it wrinkle from the center out.'
When the wrinklig stops, remove from heat source and allow to cool beer
Re: Best way to apply wrinkle black paint? [Re: TJP] #2702123
09/29/19 10:31 PM
09/29/19 10:31 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I used the Eastwood stuff. A little glossier than the factory maybe, but looks good a decade later and tough as nails.
I just followed the directions on the can. As already stated, be sure to get ALL grease and oil off--you want it spotlessly clean.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
