340 Leaf Spring Part Number Question #2701187
09/26/19 04:37 PM
09/26/19 04:37 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I’m looking to obtain the correct part number for the rear leaf springs on 70 A-Bodies. Was there a common part number used for stock 340 rear leaf springs on A-Bodies across multiple years?
Re: 340 Leaf Spring Part Number Question [Re: vinnyd76] #2701242
09/26/19 09:14 PM
09/26/19 09:14 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
only have 70/71/72 book in house- parts manual under 17-11-3 says 70-72 a body 340 take 3420183
Re: 340 Leaf Spring Part Number Question [Re: rbkt65] #2701300
09/27/19 02:28 AM
09/27/19 02:28 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
3420 183 could be a parts counter number which is often different from the factory assembly number that is usually seen on used parts.
The factory assembly number for 1971-1972 Demon/Duster is 3400 081, both sides. This might be the same for 1970, but not sure.
Re: 340 Leaf Spring Part Number Question [Re: kentj340] #2701324
09/27/19 08:58 AM
09/27/19 08:58 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the information! Anyone know if 1973 A-Bodies changed part numbers for the rear leaf? If so, will 1973 springs still attach properly to a 1970/1971 A-Body?
Re: 340 Leaf Spring Part Number Question [Re: vinnyd76] #2701367
09/27/19 11:15 AM
09/27/19 11:15 AM
New York
rarefish Online content
rarefish  Online Content
New York
Here is a shot of the original leaf springs from my 69 340 Dart.
If you have the broadcast sheet, then last 3 digits of the springs installed at the factory are on noted on the sheet.
064 in the case of my springs.
