Page 21 of 34 1 2 19 20 21 22 23 33 34
Re: Starting to work on the Duster [Re: AndyF] #2694488
09/04/19 09:17 PM
09/04/19 09:17 PM
AndyF Online content OP
AndyF  Online Content OP
I mocked up the new electrical system for the Duster using some relays and I wasn't super happy with how complicated things got. Then I came across this solid state relay from MSD that appears to solve those problems. I haven't seen anyone post about this MSD solid state relay bank so I figured I'd at least show a picture of it. I'll start running the wires once I transfer the dimensions over to piece of sheet metal.
Re: Starting to work on the Duster [Re: AndyF] #2694490
09/04/19 09:25 PM
09/04/19 09:25 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I kicked everything MSD other than my crank sensor bracket off of my car when I went EFI because I had experienced reliability problems. That being said I like the clean and simple setup those relay setups offer, and they are solid state on top of that.
68 Barracuda Formula S 340
Re: Starting to work on the Duster [Re: AndyF] #2694656
09/05/19 11:15 AM
09/05/19 11:15 AM
moparx Offline
moparx  Offline
that looks like a very clean setup andy.
and , being lazy as always, is it possible you may have a link to that ?
TIA ! bow
beer
Re: Starting to work on the Duster [Re: AndyF] #2695069
09/06/19 09:22 PM
09/06/19 09:22 PM
A buddy loaned me his Longacre alignment tool. I've never used one of these before but the process was actually pretty quick. I dialed in 1/2 camber and got about 3.5 caster and aimed for 1/8th toe. I figure that should work well enough for some shake down driving around town then I'll take it in to the local alignment shop and let the pro lock it down.
Re: Starting to work on the Duster [Re: AndyF] #2695194
09/07/19 11:51 AM
09/07/19 11:51 AM
moparx Offline
moparx  Offline
andy, those longacre tools are pretty accurate. i have a similar tool [i can't remember the name, but it was one of the first ones of that design put out], and have used it a lot.
i bought that, plus a couple of others, and i have had great luck aligning my stuff, and no goofy tire wear.
there are no good places around here to get an alignment, thus my delve into these tools.
beer
Re: Starting to work on the Duster [Re: AndyF] #2695538
09/08/19 07:25 PM
09/08/19 07:25 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
My dad (who was very cheap) used to say, "One plumb bob, two strips of angle iron, 4 C-clamps and a tape measure." Well it worked on his 46 Plymouth. LOL.
Re: Starting to work on the Duster [Re: Mopar_Rich] #2695542
09/08/19 07:33 PM
09/08/19 07:33 PM
Toe is easy to do with a tape measure and camber can be guessed at pretty well with a straight edge and bubble level but caster is the tough one. At least on a IFS. Caster wouldn't be too hard with a straight axle I suppose.
I think a person could design a fixture that measured caster directly off the knuckle but it would take some clever thinking.
Re: Starting to work on the Duster [Re: AndyF] #2695595
09/08/19 09:59 PM
09/08/19 09:59 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
With a spool the car is already hard to turn, so dialing in as much caster as you can just makes it ride better down the track.
Re: Starting to work on the Duster [Re: AndyF] #2700993
09/26/19 12:17 AM
09/26/19 12:17 AM
I finally got most of the wiring hooked up and working. Still have a few things to button up but it is getting closer.
Re: Starting to work on the Duster [Re: AndyF] #2700994
09/26/19 12:20 AM
09/26/19 12:20 AM
I ended up buying a repo air grabber setup for the car. I decided I liked the way it looked so I plunked down the money.
Re: Starting to work on the Duster [Re: AndyF] #2701010
09/26/19 05:40 AM
09/26/19 05:40 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Car is looking good Andy.
69 GTX 68 Road Runner
Re: Starting to work on the Duster [Re: JERICOGTX] #2701071
09/26/19 10:43 AM
09/26/19 10:43 AM
Oklahoma City, Oklahoma
MrMayhem Offline
MrMayhem  Offline
Funny about the air cleaner, I bought one too for my car as well some time back. I love the look of those. Heck even bought one for my 74 440 Trailduster.
I love the digital dash... is that the permanent location or are you looking to retrofit on the factory dash frame?
Re: Starting to work on the Duster [Re: MrMayhem] #2701089
09/26/19 11:36 AM
09/26/19 11:36 AM
I'll put the top part of the original dash frame back in place since that part has the VIN tag and it supports the windshield gasket. The bottom of the frame has been cut away.
Re: Starting to work on the Duster [Re: AndyF] #2701093
09/26/19 11:44 AM
09/26/19 11:44 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
You ought to talk with Hemi denny about some of his LCAs. A lot lighter.
Re: Starting to work on the Duster [Re: AndyF] #2701157
09/26/19 03:01 PM
09/26/19 03:01 PM
Here is how the actual sub panel ended up. I think the MSD solid state relay module is a cool idea. I'll probably put one in my Coronet to clean up some of the messy wiring.
Re: Starting to work on the Duster [Re: AndyF] #2701351
09/27/19 10:08 AM
09/27/19 10:08 AM
central il.
second 70 Offline
second 70  Offline
central il.
That air cleaner top would look great painted to match the valve covers. Just would have to get a filter with a black seal.
Re: Starting to work on the Duster [Re: AndyF] #2701366
09/27/19 11:08 AM
09/27/19 11:08 AM
moparx Offline
moparx  Offline
very NICE sub panel andy. up
beer
Re: Starting to work on the Duster [Re: second 70] #2701548
09/27/19 08:37 PM
09/27/19 08:37 PM
If I change the color on the air cleaner I'll probably go black, Maybe make the valve covers black too. I'm going to leave it orange for now since people expect an Air Grabber top to be orange but if I get tired of orange I'll probably powder coat it black. I don't think I'd go with the turquoise color.
Re: Starting to work on the Duster [Re: AndyF] #2701554
09/27/19 08:44 PM
09/27/19 08:44 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
If you do any road driving a 60/40 shock on the front is way more manageable. Nice car.
Re: Starting to work on the Duster [Re: mopar dave] #2701569
09/27/19 09:38 PM
09/27/19 09:38 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Very nice work! attention to detail is off the charts!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
