81 4spd clutch pedal #2700934
09/25/19 08:49 PM
09/25/19 08:49 PM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
What are you guys with 4spds getting replacement parts for clutch pedal rod from pedal to z bar? Mines wore and needs replaced
Re: 81 4spd clutch pedal [Re: roadrunnerreds] #2700939
09/25/19 09:02 PM
09/25/19 09:02 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
You are better off making your own from heim joints. It will never wear out, it's adjustable and eliminates slop. All of the used originals are worn out. twocents
