Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon
[Re: 68rrunner]
#2704722
10/07/19 09:46 PM
10/07/19 09:46 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
so buy different UCA's, that would give you the super big brakes and I am not impressed with hotchkiss stuff. I think that Heims are [censored] joints for steering. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: dangina]
#2709914
10/25/19 12:37 AM
10/25/19 12:37 AM
Posts: 27,469 So Cal
autoxcuda
So Cal
I have this combo hotchkis arms 13" viper calipers - the only problem I had was I couldn't run the 17" rims I wanted - upgraded to 18" Are you calipers mount in the front or in the back? The Hotchkis A-body arm have a wide turn in the rear and can interfere with some rear mounted calipers. I think E-body's don't do that.
[Re: tahoechallenge]
#2710255
10/26/19 08:55 PM
10/26/19 08:55 PM
Posts: 22,696 Bitopia
jcc
Bitopia
A 15" brake with a wheel adapter ? Got to be more behind that story.
[Re: autoxcuda]
#2711239
10/30/19 01:15 PM
10/30/19 01:15 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I have this combo hotchkis arms 13" viper calipers - the only problem I had was I couldn't run the 17" rims I wanted - upgraded to 18" Are you calipers mount in the front or in the back? The Hotchkis A-body arm have a wide turn in the rear and can interfere with some rear mounted calipers. I think E-body's don't do that. Mounted on the back! the rims were the year one rallye rims - The problem was the inside of the rim was rubbing against the top of the caliper...
