Re: Hemi Cuda.....1st Pass Off the trailer tonight
[Re: JERICOGTX]
#2700085
09/23/19 10:53 AM
09/23/19 10:53 AM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
Nice!
I was wondering where the roll cage was, too. Since he is running IHRA, he doesn't need a cage until 9.00 or faster. Does need a IHRA license though to go under 6.40, or 10.00. You do need the halo bars ro run quicker than 9.99 in IHRA. A 6 or 8 point rollbar is only good to 10 flat
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: quickd100]
#2700086
09/23/19 10:57 AM
09/23/19 10:57 AM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
At what rpm are you shifting? Didn't look like it was going much past 6000. I was shifting around 6500. The Rev limiter you can't here it. But I had to go change it to spin it higher. Plus it was a little lean I think yet as it was not climbing rpm real quick yet. Ran out of jet sizes at #106.... And it needs a full cage and window net anything below 6.50..... After reviewing a copy of the vids it appears I shifted closer to 6200....
[Re: Dragula]
#2700121
09/23/19 12:36 PM
09/23/19 12:36 PM
B3422W5
Portage,michigan
Seems wierd the car would want so much jet. Seems like a ton I had a motor that made similar power to this one that ran 88/90 jets. Actually 135 mph at 3350
[Re: B3422W5]
#2700123
09/23/19 12:43 PM
09/23/19 12:43 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Seems wierd the car would want so much jet. Seems like a ton I had a motor that made similar power to this one that ran 88/90 jets. I was thinking the same thing. Is this a Thumper-modified carb?
[Re: Dragula]
#2700148
09/23/19 02:17 PM
09/23/19 02:17 PM
Posts: 422 montana
BANDIT
montana
How old/ how many passes on your current tires?
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: 70satelliteguy]
#2700165
09/23/19 03:22 PM
09/23/19 03:22 PM
Posts: 216 America
WedgeFED
America
"Seems wierd the car would want so much jet. Seems like a ton I had a motor that made similar power to this one that ran 88/90 jets. "
Yeah! My 572 Wedge with Quickfuel 1450 is jetted 96 square! Mid 9s at 138. Wondering what carb or combo would need even MORE than 106. Mike Saw a little small block car with jets in the 170 range a few weeks ago and yes on race gas...
[Re: WedgeFED]
#2700176
09/23/19 04:22 PM
09/23/19 04:22 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
If you are still running the Indy Hi-Po heads shifting at 6200 you haven't even hit the Hp peak in the powerband. They are real lazy down low. I pulled mine to just passed 6700, the Hp was still climbing.
[Re: blowndart]
#2700214
09/23/19 06:38 PM
09/23/19 06:38 PM
Dragula
Seems wierd the car would want so much jet. Seems like a ton I had a motor that made similar power to this one that ran 88/90 jets. I was thinking the same thing. Is this a Thumper-modified carb? Its a Thumper 1250 carb and its on pump gas 93 with E10, so that requires an AFR of around 12.2....Friday nights pass showed it was close to 13.8 in high gear. Saturday I went up from #104 to #106, and it looks like its around 12.5-12.8 now. I still had jets in my hand when they called us to the lanes....But it was much better, and I gained almost 2mph in the 1/8th.....So it probably just needs to go 1-2 more. I will order them, but I doubt I will run this car again this year. My belts are out and I was lucky they let me run actually let alone, I made it down to the last four cars....Not too bad for a street car. Going to have to figure out what kind of tire to put on it for next year. Thinking of trying a 315DR in R2 compound....Its shorter and will kick the rpm a little. And yes Hi-Po big valve heads still....I could tell it wasn't pulling real good yet, so the jetting needed to be better before pulling it that high, and my 20 year old 7k rev limiter chip was hitting at 6600....
[Re: Dragula]
#2700323
09/24/19 03:56 AM
09/24/19 03:56 AM
Guitar Jones
I'm thinking if you need that much jet you need more than one carb. Sounds sweet though and yeah, your RT's are insane for a foot brake car.
[Re: Dragula]
#2700355
09/24/19 08:16 AM
09/24/19 08:16 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Put a 315 pro on it. I'd definitely spin it higher w/ those big heads and manifold. I'm also very surprised it needs that much jet. My 1200 dominator (mod'd 1150) is 88/96 w/ a PV up front.
[Re: Dragula]
#2700380
09/24/19 09:34 AM
09/24/19 09:34 AM
blowndart
Odessa, Fl
[ Its a Thumper 1250 carb and its on pump gas 93 with E10, so that requires an AFR of around 12.2....Friday nights pass showed it was close to 13.8 in high gear. Saturday I went up from #104 to #106, and it looks like its around 12.5-12.8 now. I still had jets in my hand when they called us to the lanes....But it was much better, and I gained almost 2mph in the 1/8th.....So it probably just needs to go 1-2 more Assuming that you AFR meter is accurate, it looks like you're close that what that carb wants. Thanks for posting the videos. Must feel great to get it out and race it after all that you've been through with that engine.
[Re: blowndart]
#2700542
09/24/19 05:59 PM
09/24/19 05:59 PM
Dragula
Yeah! My 572 Wedge with Quickfuel 1450 is jetted 96 square! Mid 9s at 138. Wondering what carb or combo would need even MORE than 106. Mike Well, the plenum on that intake is huge as well as the runners and I took the clover leaf out.....So the MPH is telling me its lean, and so is the AFR guage, so I am going up....My 1000cfm 4150 on my 512 had 96's in it, my 1050 Thumper on my 512 has 104's in it.....Seems about right.... How old/ how many passes on your current tires? Tires are old and shot, the side wall is just getting obliterated even at 14psi......What is the best hooking tire for a leaf spring car in a 31x16.5 or 315 radial? [ Its a Thumper 1250 carb and its on pump gas 93 with E10, so that requires an AFR of around 12.2....Friday nights pass showed it was close to 13.8 in high gear. Saturday I went up from #104 to #106, and it looks like its around 12.5-12.8 now. I still had jets in my hand when they called us to the lanes....But it was much better, and I gained almost 2mph in the 1/8th.....So it probably just needs to go 1-2 more Assuming that you AFR meter is accurate, it looks like you're close that what that carb wants. Thanks for posting the videos. Must feel great to get it out and race it after all that you've been through with that engine. It does finally feel good. After what I went thru with the Indy block, I can tell you, this engine, with all the same parts as before, holds way better oil pressure, and makes more power. Its already .05 quicker and it weighs more than 200lbs more.
[Re: Dragula]
#2700681
09/25/19 08:18 AM
09/25/19 08:18 AM
an8sec70cuda
PUT A 315 ET STREET PRO ON IT.
[Re: Dragula]
#2700707
09/25/19 09:33 AM
09/25/19 09:33 AM
an8sec70cuda
Beadlocks are nice and preferred if you can afford them. I can't, so I use permatex to glue the beads. I also ran screws in radials for 10+ years and had no problems, but now they say not to do that b/c it can hurt the tire.
[Re: an8sec70cuda]
#2700962
09/25/19 10:27 PM
09/25/19 10:27 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Beadlocks are nice and preferred if you can afford them. I can't, so I use permatex to glue the beads. I also ran screws in radials for 10+ years and had no problems, but now they say not to do that b/c it can hurt the tire. Champion wheels bridged the price gap for beadlocks. Too bad they're out of the game!
