Trick Flow intake on Eddie heads ?
#2700488
09/24/19 03:12 PM
09/24/19 03:12 PM
Posts: 179 California, U.S.A.
Torquemonster440
California, U.S.A.
Hey all, just looking for some feed back, or opinions as to how the new TF intake would perform on a "replacement " style aluminum headed 440 ? Something with a 210cc runner , i.e. Stealths,Eddie's, or Promaxx's like I have on my car..I have the .528 purpleshaft and a Performer RPM intake on the 440 now and I really like it. I was just contemplating upgrading to the TF intake and possibly the .557 purple shaft, since that intake and cam both come on at 3k rpm. On paper, it looks like that combo would play real well with my 9.5" 3600 converter and 3.91 gears on 28" tires. My cr is 10.3-1. Any real world feed back on the TF intake is much appreciated. The runner length looks like it would still make great torque reasonably low.
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Trick Flow intake on Eddie heads ?
[Re: Torquemonster440]
#2700502
09/24/19 03:58 PM
09/24/19 03:58 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
To be honest, the only way to know is to try it & compare track times.
[Re: CSK]
#2700506
09/24/19 04:08 PM
09/24/19 04:08 PM
Torquemonster440
California, U.S.A.
Absolutely, ..I was just hoping someone already had the track time or Dyno info and was willing to pass it along.
[Re: AndyF]
#2700524
09/24/19 05:04 PM
09/24/19 05:04 PM
Torquemonster440
California, U.S.A.
Thanks for your input Andy, much appreciated. It was because of your research that I chose the .528 cam I'm running now. Do you feel the TF intake would be a poor match for the .528 cam? I keep telling myself to keep this build conservative, but the more it progresses I keep leaning toward a more bracket race approach. It's just a weekend thrasher that I take to the track 2-3 times per year.. it needs body work and interior, but going faster always seems to take priority. Lol.
[Re: AndyF]
#2700573
09/24/19 07:48 PM
09/24/19 07:48 PM
Torquemonster440
California, U.S.A.
I have been running it with the RPM for about 5 years now, it has always ran well with that intake. I have since upgraded my heads, converter and exhaust. .. I'm just kicking the idea around of trying a single plane. The TF looks like about the best available today as far as an "as cast" piece goes. I was just curious if anyone has A/B tested the RPM vs the TF. Sounds like I'm just gonna have to pull the trigger on the TF and see what it does. Thanks for the input Andy.
[Re: BradH]
#2701034
09/26/19 08:37 AM
09/26/19 08:37 AM
Torquemonster440
California, U.S.A.
Have you tried an open spacer with the Performer RPM to see if it responds to a larger plenum? The Trick Flow doesn't sound like a good match for the combination described. Yes, I run it with a 1" open phenolic spacer.. it seems to like it. My initial purpose for the spacer was to keep heat off the carb. Part of the reason I'm considering the TF intake is because my combo is not very far off from the combo featured in their ads. My compression, my c.i.d. , my cam duration, my carb and exhaust are all very similar to the combo they cited in their ads. You know, the combo that produced 620 hp. !! however inflated those numbers may be, the only big differences between my combo and theirs are the heads, the TF 240's vs my 210 cc aluminum heads[I know, this one is a biggie] and the big single plane intake vs. my performer RPM. I really like the looks of the TF intake and I think my e.t. would benefit from a little extra top end charge.
[Re: krautrock]
#2701057
09/26/19 10:05 AM
09/26/19 10:05 AM
Torquemonster440
California, U.S.A.
what does you car run right now? did it pick up going from (i'm assuming from your signature) the 906 heads to the promaxx heads? did you port match and open up the pushrod pinch in the promaxx heads? That is a good question.. lol.. I haven't been to the track yet since the head swap. Waiting for it to cool down a bit out here in So Cal. Probably early Nov I'll be hitting the track. As for opening up the pushrod pinch, I didn't, because the pushrod pinch on the Promaxx's vs the 906's was huge !! I could fit the box end of a 3/4" wrench trough the Promaxx's pinch area.. I could barely get the 3/4 into the port on the 906's. And, Brad is right... I'm kinda fishing for someone to tell me to go with the single planene.. lol !! Over all, the purpose of this post is, I was curious if anyone has tried and tested this swap on a combo similar to mine.
[Re: krautrock]
#2701119
09/26/19 12:40 PM
09/26/19 12:40 PM
Torquemonster440
California, U.S.A.
[spoiler][/spoiler] ^ yeah...
isn't an intake swap on a big block pretty easy? do the swap on the same day at the track and find out what you pick up or lose... Intake swap on a 440 is super easy.. just the carb and 8 bolts. I'll probably need to jet up from the dual plane.. ? Sounds like a good idea. I just gotta cough up the $350 for the TF intake. Pretty sure I won't find one used.
#2701138
09/26/19 01:47 PM
09/26/19 01:47 PM
Posts: 31,060 Oregon
AndyF
isn't an intake swap on a big block pretty easy? do the swap on the same day at the track and find out what you pick up or lose... Intake swap on a 440 is super easy.. just the carb and 8 bolts. I'll probably need to jet up from the dual plane.. ? Sounds like a good idea. I just gotta cough up the $350 for the TF intake. Pretty sure I won't find one used. You're just late to the party. I did back to back testing last year and then sold my slightly used Trick Flow intake to a Moparts member.
[Re: AndyF]
#2701144
09/26/19 02:03 PM
09/26/19 02:03 PM
Torquemonster440
California, U.S.A.
isn't an intake swap on a big block pretty easy? do the swap on the same day at the track and find out what you pick up or lose... Intake swap on a 440 is super easy.. just the carb and 8 bolts. I'll probably need to jet up from the dual plane.. ? Sounds like a good idea. I just gotta cough up the $350 for the TF intake. Pretty sure I won't find one used. You're just late to the party. I did back to back testing last year and then sold my slightly used Trick Flow intake to a Moparts member. Story of my life Andy.. lol.. what intake did you test it aginst?
[Re: BradH]
#2701165
09/26/19 03:25 PM
09/26/19 03:25 PM
Torquemonster440
California, U.S.A.
Wow, those look pretty crazy.. have you ever tried one Brad? My only issue is, I want to stay with something that will insulate the carb against heat Better than aluminum.
