bracket racer question #2700466
09/24/19 01:45 PM
09/24/19 01:45 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
my son says that to be very consistent you need to monitor coolant, engine oil, trans and even rear end temps. My question is what makes the car faster? hot trans and rear oil temps?
....BAD A$$ STREET CAR.....
Re: bracket racer question [Re: n20mstr] #2700475
09/24/19 02:10 PM
09/24/19 02:10 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
cold to warm the car will go faster with warm fluids providing the warm engine doesn't have a draw back like hot intake air temp due to a stock hood or something.
My car is very consistent, I drive to the track so the fluids all get good and warm and I imagine stay a pretty good constant throughout the day since there is never a warm up from cold to be done at the track. I have an electric water pump and fans so I can hit the burnout box at the same temp every time. My car never loses a race these days, its always that guy that tells it when to go lol.
68 Barracuda Formula S 340
Re: bracket racer question [Re: Bad340fish] #2700477
09/24/19 02:15 PM
09/24/19 02:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The car will be fastest with the engine coolant as cool as possible, while having the engine oil, trans fluid and rear end up to temp or hotter. Also cold fuel will pick up a little as well. When we need a "hero" run we chill the fuel, heat the engine oil and diff and make sure the trans is thoroughly warmed with the brake. No other real way to get a fair amount of heat in the trans in a small amount of time. As for consistency you are looking for just that across the board. A lot of guys struggle with their first hit off the trailer being a "throw" away from the rest IMO the main reason is trans temp. Just not enough heat in it without making a hit. There is a reason people putting in the air and lay on the brake.
Re: bracket racer question [Re: Al_Alguire] #2700487
09/24/19 03:09 PM
09/24/19 03:09 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
Also ice down the intake manifold, push the car up to the lanes, air up the front tires, drain a quart or so of oil, angle stage the car if you can get away with it.... just hang out in the stock/super stock pits and watch and listen. You will pick up lots of tricks before class eliminations.
Re: bracket racer question [Re: BIG DRAG] #2700510
09/24/19 04:25 PM
09/24/19 04:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Definitely what stock and SS guys do. I was referring to a heads up car which already does many of those things every round. We don't ice intakes as most of us run fuel that ices them for us smile but we do make sure the fuel is COLD going in right when we get called. We run as little oil capacity, viscosity(we run zero weight all the time) and pressure as we can get away with. We also run light oil in the diff and again as little as we can get away with, not to mention ceramic bearings EVERYWHERE.
Re: bracket racer question [Re: BIG DRAG] #2700511
09/24/19 04:28 PM
09/24/19 04:28 PM
Not if you listen to all those guys, what works on a Ford or Chevy, especially dumping a quart of oil out, doesn't work on BB Mopars tsk
Been there, done that for over twenty years running a M.W , Hemi and SB cars in NHRA stock and helping other Mopar racers in stock, S/ST,S/G and so on work
Re: bracket racer question [Re: n20mstr] #2700554
09/24/19 06:53 PM
09/24/19 06:53 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Flickering the stage bulbs
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
