383 Carter Fuel Pump #2698519
09/17/19 05:33 PM
09/17/19 05:33 PM
MoreParts Offline OP
Hey guys, I think it's time for me to replace my fuel pump. Do any of you have a recommendation on one that looks like the original but can take today's harsh fuel? The car is a '70 Challenger w/383 Magnum.
Thanks!
Re: 383 Carter Fuel Pump [Re: MoreParts] #2698534
09/17/19 06:36 PM
09/17/19 06:36 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I bought a Holley manual pump and it is a carter pump with the carter name removed literally . I used 2 new carters that were bad out of the box so I tried a Holley and it is still working been a month now.
Re: 383 Carter Fuel Pump [Re: hemirdrnnr] #2698539
09/17/19 06:45 PM
09/17/19 06:45 PM
This is not instilling me with confidence. wink It looks like I need a Carter M4589 which I was happy to learn is still made in the USA. I just got of chat with their tech and they claim it's been updated for today's fuels too. Airtex has one that is supposed to be compatible with the new fuels as well, but a little research showed a lot of unhappy customers.
Re: 383 Carter Fuel Pump [Re: MoreParts] #2698541
09/17/19 06:51 PM
09/17/19 06:51 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
The Holley I bought had a warranty card if it goes bad. One thing good about it I can change one now taking my time in less that 20 minutes not bad for a man with 9 thumbs and a broke finger. wrench
Re: 383 Carter Fuel Pump [Re: hemirdrnnr] #2698542
09/17/19 06:53 PM
09/17/19 06:53 PM
Well come on over and do mine! I've got a beer for you too. I'll bet you're using a Hemi fump? I can't seem to find a listing for a lowly 383 Magnum engined car.
Re: 383 Carter Fuel Pump [Re: MoreParts] #2698547
09/17/19 07:01 PM
09/17/19 07:01 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
If your are any where near Mobile we can do!
Re: 383 Carter Fuel Pump [Re: hemirdrnnr] #2698555
09/17/19 07:20 PM
09/17/19 07:20 PM
LOL, I'm no where near a Mobil Oil station. I'm in California. Home of the fuel pump killers. Thanks though, I appreciate your input!
Re: 383 Carter Fuel Pump [Re: MoreParts] #2698589
09/17/19 09:48 PM
09/17/19 09:48 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Even if I add element 115 to the Ole Belvedere I don't think I could make it to Cali in time to help you.
Re: 383 Carter Fuel Pump [Re: hemirdrnnr] #2698636
09/18/19 02:06 AM
09/18/19 02:06 AM
Sobieski Wi
bee1971 Online work
bee1971  Online Work
Sobieski Wi
Same one as my 1971 383 Magnum Bee
My local jobber Bumber to Bumper got me a Delphi MF0060
https://www.summitracing.com/parts/dfp-mf0060
https://www.mybumpertobumperstore.c...trtrZ5AIVlI3ICh1pawBqEAUYAiABEgKyn_D_BwE
Our lowly 383 cars came from the factory with 5/16” fuel lines
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 383 Carter Fuel Pump [Re: bee1971] #2698722
09/18/19 12:40 PM
09/18/19 12:40 PM
Thanks for the links, Bee. I'm still inclined to use the Carter because it's the one I've confirmed is updated to hold up to the lousy fuel, and I can see they're using a more modern gasket too. Plus I like that factory name. How long has your Delphi been in service?
Re: 383 Carter Fuel Pump [Re: MoreParts] #2700275
09/23/19 09:13 PM
09/23/19 09:13 PM
hmmm, so I got my new Carter in. But the install is fighting me. Do I need to pull out the push rod? For whatever reason it does not want to sit right when I go to bolt it up. Taking it off though was a piece of cake. Any tips would be appreciated!
Re: 383 Carter Fuel Pump [Re: MoreParts] #2700297
09/23/19 10:55 PM
09/23/19 10:55 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
You might have to bump the motor over so you can push the rod up some. might have to use some heavy grease on the rod to hold it up until you get the pump in and bolts started. Hope this helps.
Re: 383 Carter Fuel Pump [Re: pushbutton] #2700301
09/23/19 11:23 PM
09/23/19 11:23 PM
Somehow I remember my last install from about 25 years ago and bumped it. No grease though. Fingers crossed no leaks tomorrow when I start it!
Re: 383 Carter Fuel Pump [Re: MoreParts] #2700327
09/24/19 05:53 AM
09/24/19 05:53 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I had to bump one of mine and it went right in , the other two were no problem let us know.
Re: 383 Carter Fuel Pump [Re: hemirdrnnr] #2700399
09/24/19 10:23 AM
09/24/19 10:23 AM
You are a lucky cat. I don't remember it being such a pain last time. This time it took 3 bumps.
I have not started it yet. I'm almost reluctant too because I'll go nuts if I see a leak. But a few observations I noticed re the old and new pumps:
1) The one I pulled had a '68 date code. Could that have been original to my '70? I'm not sure if I reused the original when I went through the engine 25 years ago or I bought an NOS replacement.
2) The new Carter had no markings on it.
3) The new Carter came with 2 sets of green gaskets. They were poor. The bolt holes were too small so every time I'd go to secure it against the mating surface it would pull the gasket off the pump. Eventually they both tore so I went to Autozone that sold a blue colored one with the proper sized holes. I only put the gasket maker on the fuel pump side to hold it in place. I'm hoping just using it on the one side doesn't make it more leak prone. I did torque it to 30lbs spec so it does not seem likely.
Re: 383 Carter Fuel Pump [Re: MoreParts] #2700578
09/24/19 07:58 PM
09/24/19 07:58 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I put the sealer on the pump and it hasn't leaked yet , one of the bolt holes was too small on one of the pumps and I reamed it enough to get the bolt in. I am sure someone on here could tell you about the date code I would hesitate to speculate because it can be hazardous to your health you get pounced on quicker than a doughnut at a big girl convention. I primed my carburator with a little gas to help the pump get primed good luck.
Re: 383 Carter Fuel Pump [Re: hemirdrnnr] #2700589
09/24/19 08:34 PM
09/24/19 08:34 PM
It started! I do my usual crank for about 10 seconds. Let it sit for 10 then pump it twice and crank again as my normal routine when I let her sit for a long while. This time since it was dry I had to do it twice, but it fired up no leaks!. I did get a humming noise scare when it first started that my mind immediately told me was a bad pump. Turns out I'd left my alternator belt a bit loose when I was tightening things back up.
Okay, for the fuel pump date code pros is it possible that 2 years prior to my build date is in the realm of possibility for a 383 car fuel pump or is it more likely a NOS unit I picked up 25 years ago?
Re: 383 Carter Fuel Pump [Re: MoreParts] #2700791
09/25/19 02:10 PM
09/25/19 02:10 PM
BlueRacer69 Offline
BlueRacer69  Offline
More then likely it was a NOS unit you picked up along the way. Pumps that are 2 years before your cars build date is a long time. That's not normal.
Re: 383 Carter Fuel Pump [Re: BlueRacer69] #2700845
09/25/19 04:08 PM
09/25/19 04:08 PM
I was leaning that way too, but I figured it's such a high production engine for so many years that maybe the parts for it were well stocked. Either way, I'm okay and I'll hold on to it.
