Roller cam and rocker manufacturer reccomendation?
#2699862
09/22/19 01:27 PM
09/22/19 01:27 PM
Posts: 2,158 God's Country - Etowah, TN.
A34
Hey Guys,
Who do you recommend for a roller cam, lifters and rocker arm assembly? Also, who do you NOT recommend. This is for a mild 440.
Thanks in advance!
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: Roller cam and rocker manufacturer reccomendation?
[Re: Mopar Guy]
#2699900
09/22/19 04:45 PM
09/22/19 04:45 PM
A34
Thanks! Yes, Hydraulic roller.
Would you have contact info by chance?
DEO VINDICE
[Re: A34]
#2699939
09/22/19 08:11 PM
09/22/19 08:11 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Would you have contact info by chance? Eight zero two - nine five one- one nine five five he’s usually in from about 9am-6pm My opinion, and Dwayne may disagree, is my first choice wouldn’t be Comp hyd. roller lifters, and even wouldn’t suggest Morels at this point, based on some current trends. Dwayne knows how to catch me if need be. Dwayne will get you a good cam, stick with his advice.
RIP Monte Smith
[Re: CompWedgeEngines]
#2700022
09/23/19 05:00 AM
09/23/19 05:00 AM
Posts: 427 Sweden
Mopar Guy
Sweden
Would you have contact info by chance? Eight zero two - nine five one- one nine five five he’s usually in from about 9am-6pm My opinion, and Dwayne may disagree, is my first choice wouldn’t be Comp hyd. roller lifters, and even wouldn’t suggest Morels at this point, based on some current trends. Dwayne knows how to catch me if need be. Dwayne will get you a good cam, stick with his advice. What kind of some current trends regarding morels lifters ? I never heard of any going bad ! I have seen comp cams roller lifter that pin for roller came out !
[Re: A34]
#2700099
09/23/19 11:16 AM
09/23/19 11:16 AM
Posts: 43,173 Bend,OR USA
Cab_Burge
Call Comp Cams 800-365-9145, Bullet 662-893-8022 and Ultra Dyne 662-893-8022 and compared there recommendations for you and go from there. As far as hydraulic roller lifters I don't use them due to not being able to get good trouble free lifters from any company out there so far Adjustable rocker arms are a different deal all together, don't buy cheap import aluminum roller tips, NO GOOD As already mentioned Comp Cams stainless steel, Crane aluminum and ductile iron rockers, Isky ductile iron and maybe RAS 530242-1316 if they have any in stock and maybe Hughes aluminum for street use
