Re: 6.4 block questions
[Re: scottb]
#2699751
09/22/19 09:52 AM
09/22/19 09:52 AM
Posts: 33 Northern California
B5 Classic
Northern California
The 392 BGE truck block IS a Hellcat block, or vice versa, except for color. The 392 SRT block is a pretty good block, but I don't know that I'd build it to 1,000 hp while knowing there's a stronger block available. FCA has never really said how much stronger the BGE block is, they've just provided bits of information for mag and tech articles, stating it's been strengthened here and there.
I have a brand new Hellcat block (the orange one) I'm probably going to sell. I bought it to build, but then bought a Hellcrate engine when they came out. Really don't have use for the bare block now.
[Re: B5 Classic]
#2699788
09/22/19 11:03 AM
09/22/19 11:03 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
I have a brand new Hellcat block (the orange one) I'm probably going to sell. I bought it to build, but then bought a Hellcrate engine when they came out. Really don't have use for the bare block now. After 2016 they are the same block,(different colors) the 6.4 blocks have a thinner cylinder casting and they don't have the ribs joining the bottom of the cylinders together in the water jacket. I don't know about the 6.4 blocks but I've seen BGEs go well in to the high 1400hp. My Hennessy Demon is just over 1100 at the wheels and has about 6500 mile on the build.
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: fbs63]
#2699989
09/22/19 10:35 PM
09/22/19 10:35 PM
B5 Classic
Northern California
One BIG difference between the Hellcat and BGE block is the water jackets. The BGE water jackets are about 11/2" shorter. There is alot of solid cast iron in the bottom end of that block. Add billet main caps and it will take alot. Wondering, have you personally seen and compared the difference between the black BGE block (truck 6.4) and the orange BGE block (Hellcat) ? I keep reading everywhere that they both have the shorter water jackets. If you have a black BGE block, I have an orange one. Maybe we can compare some measurements...
[Re: fbs63]
#2700046
09/23/19 08:49 AM
09/23/19 08:49 AM
Posts: 1,551 USA
hudsonhornet7x
USA
One BIG difference between the Hellcat and BGE block is the water jackets. The BGE water jackets are about 11/2" shorter. There is alot of solid cast iron in the bottom end of that block. Add billet main caps and it will take alot. I was under the impression that any block with the BGE cast into it was the same. So there are different water jackets in BGE blocks?
[Re: hudsonhornet7x]
#2700060
09/23/19 09:30 AM
09/23/19 09:30 AM
Ray408G3Hemi
Springtown Pa
One BIG difference between the Hellcat and BGE block is the water jackets. The BGE water jackets are about 11/2" shorter. There is alot of solid cast iron in the bottom end of that block. Add billet main caps and it will take alot. I was under the impression that any block with the BGE cast into it was the same. So there are different water jackets in BGE blocks? No ,..... the 6.4(11-17) is different from the BGE(14+) see the bumped BGE thread
[Re: Ray408G3Hemi]
#2700150
09/23/19 02:33 PM
09/23/19 02:33 PM
Posts: 1,551 USA
hudsonhornet7x
USA
One BIG difference between the Hellcat and BGE block is the water jackets. The BGE water jackets are about 11/2" shorter. There is alot of solid cast iron in the bottom end of that block. Add billet main caps and it will take alot. I was under the impression that any block with the BGE cast into it was the same. So there are different water jackets in BGE blocks? No ,..... the 6.4(11-17) is different from the BGE(14+) see the bumped BGE thread I agree with you. The statement though made it sound like the Hellcat and the BGE were different blocks. My Hellcat block has BGE cast right into it.
[Re: fbs63]
#2700458
09/24/19 01:11 PM
09/24/19 01:11 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
Just checked the BGE block I have on my shop floor right now is 1.5 inches less water jacket depth than an early or late 5.7 blocks I also have sitting here. Also the bores are siamesed about 1/2 the distance up VS the 5.7 bores not touching each other the entire length of those longer water jackets.
[Re: HotRodDave]
#2700460
09/24/19 01:15 PM
09/24/19 01:15 PM
HotRodDave
Kalispell Mt.
BGE is for big gas engine, they did not just say 6.4 as it would be inacurate when used as a hellcat and visa versa so they just called it BGE. They could have done like chevy did with the 4.8 and 5.3 ID on all 4.8 and 5.3 blocks. The only confusing thing for me is what I am going to build this BGE thing for, kinda hoping to find me a nice 09+ 4 door 4x4 1500 truck.
[Re: HotRodDave]
#2700674
09/25/19 07:46 AM
09/25/19 07:46 AM
Ray408G3Hemi
Springtown Pa
Just checked the BGE block I have on my shop floor right now is 1.5 inches less water jacket depth than an early or late 5.7 blocks I also have sitting here. Also the bores are siamesed about 1/2 the distance up VS the 5.7 bores not touching each other the entire length of those longer water jackets. same with the 6.1s and the 5037471BF 6.4 block the cylinders don't touch at the bottom,
