Question about instrument cluster #2698417
09/17/19 11:57 AM
09/17/19 11:57 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
]Hi!
I got a question about the instrument cluster ..I want to swap mine out..
It has tach,speedo, fuel and temp with small window that I think is information
Center.. the one I found with what I have plus amp and oil pressure gauge ..
My question is will it work on my truck?? Thank guys!
The one I have will show mileages and tell you if the Eco is on or not and it will say low oil li shruggy
Re: Question about instrument cluster [Re: BigTerry] #2698819
09/18/19 11:29 PM
09/18/19 11:29 PM
Originally Posted by BigTerry
]Hi!
What brand, year and model truck?
If it is a Dodge truck maybe the truck section guys might be a better source for this question work twocents
Re: Question about instrument cluster [Re: Cab_Burge] #2698878
09/19/19 08:24 AM
09/19/19 08:24 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
It a 2010 dodge 1500
Re: Question about instrument cluster [Re: BigTerry] #2718273
11/21/19 11:52 PM
11/21/19 11:52 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
any thing?
Terry Sansom
Re: Question about instrument cluster [Re: BigTerry] #2718349
11/22/19 11:35 AM
11/22/19 11:35 AM
md
mopars4ever Offline
mopars4ever  Offline
md
check ramforum.com lots of good info there
Re: Question about instrument cluster [Re: BigTerry] #2718630
11/23/19 01:15 PM
11/23/19 01:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Instrument cluster swaps on newer vehicles with the CAN buss can be tricky. If you're going from non-EVIC to EVIC, you'll need the steering wheel switches.
