Dana 60 bearing noise #2697340
09/13/19 11:07 PM
09/13/19 11:07 PM
State, country, etc.
gss Offline OP
gss  Offline OP
My Dana 60 rear is rumbling pretty good when I brake with the engine. No noise on acceleration and nothing obvious on cornering. I am guessing a carrier side bearing is pitted. Pinion bearings tend to whine rather than rumble in my experience. I found out the pinion threads are galled when I replaced the pinion seal a couple years ago so if the pinion bearing is bad, I will need a new ring and pinion. down
I am wondering if I should press off the axle bearings for inspection. They feel pretty smooth but I can't see enough of the rollers to see if they are bad. I would hate to damage good axle bearings. Press them off or go straight to the carrier?
Re: Dana 60 bearing noise [Re: gss] #2697358
09/14/19 12:49 AM
09/14/19 12:49 AM
Can you test it on jack stands with a stethoscope? If so try that scope
Re: Dana 60 bearing noise [Re: Cab_Burge] #2697378
09/14/19 06:31 AM
09/14/19 06:31 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Probably not the axles bearings. They sound worse on cornering. Pull the cover and check for metal in the oil with a magnet. That will tell you about the inside. Get ready to spend some money on rebuilding a Dana. Take it to someone who’s good. I just rebuilt one. They are time consuming.
Re: Dana 60 bearing noise [Re: fastmark] #2697394
09/14/19 09:04 AM
09/14/19 09:04 AM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
It could be the front pinion bearing. I think the pinion gear loads against the rear bearing on acceleration, and the front bearing on deceleration, because of the hypoid gear teeth.
Re: Dana 60 bearing noise [Re: BLACKHEMIRR] #2697547
09/14/19 05:53 PM
09/14/19 05:53 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
& make sure the pinion nut didn't come loose
