727 kickdown bracket #2697166
09/13/19 11:46 AM
09/13/19 11:46 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Do you know if this would work with headers to,with the 70-76 abody big block swaps to?i put a 68 440 into a 71 dart im runnin Schumacher headers.i tried c-body and b-body levers they hit the some of header flange and bolt. https://www.ebay.com/itm/382879892695?ul_noapp=true
or Mancini Racing - Transmission Bell Crank Pivot Assembly- https://www.manciniracing.com/hofftbcpa1.html
Re: 727 kickdown bracket [Re: mopar muscle7271] #2697305
09/13/19 08:15 PM
09/13/19 08:15 PM
las vegas,nv
las vegas,nv
Re: 727 kickdown bracket [Re: mopar muscle7271] #2697314
09/13/19 08:51 PM
09/13/19 08:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My RB-A-body setup was different than yours, Indy heads & single-plane intake with TTi headers;
No room for any of that, even a kickdown cable was a tight fit.
Obviously the factory had a kickdown setup for the stock 440 A-bodies, but I don't know the specifics.
Rhinodart here is likely the guru on that deal, I'll volunteer him !
Re: 727 kickdown bracket [Re: topside] #2697362
09/14/19 01:33 AM
09/14/19 01:33 AM
las vegas,nv
las vegas,nv
Ok thanks hopefully he will see this and reply.
Re: 727 kickdown bracket [Re: mopar muscle7271] #2698092
09/16/19 02:19 PM
09/16/19 02:19 PM
las vegas,nv
las vegas,nv
