Re: 727 High Stall Convertor ID
[Re: elmor353]
#2696891
09/12/19 01:29 PM
09/12/19 01:29 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
692 is an 11" hi-stall 727 converter used with '78-later 360 LA. It has a single 120 gram triangular weight.
[Re: elmor353]
#2697259
09/13/19 05:17 PM
09/13/19 05:17 PM
John_Kunkel
Rio Linda, CA
Show a pic of the engine side.
[Re: elmor353]
#2697445
09/14/19 12:20 PM
09/14/19 12:20 PM
John_Kunkel
Rio Linda, CA
With the weight removed it's no longer a 692, it's more akin to the earlier 762. The main difference is the absence of a drain plug which was eliminated in '77.
[Re: John_Kunkel]
#2697704
09/15/19 10:14 AM
09/15/19 10:14 AM
Posts: 19,406 north of coder
moparx
i've often considered installing drain plugs in a few converters over the years. is it practical, or will it unbalance the converter ? if it is something that can be done, how would a guy determine the correct placement of the drain, and what would the length of the drill be limited to so to protect against damaging the internals ?
