VVT computer #2695755
09/09/19 12:00 PM
09/09/19 12:00 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, so I may have missed it, but does someone make a PCM for mopar engines with VVT? I would like to see if I could use all of the features the newer hemi engine has, to include better economy. I am also looking at options for the 3.6 pentastar motor.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: VVT computer [Re: astjp2] #2695970
09/09/19 10:19 PM
09/09/19 10:19 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Factory PCM can be made to work with a factory harness and will run the vvt
Re: VVT computer [Re: L4staero] #2696037
09/10/19 07:31 AM
09/10/19 07:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The Megasquirt 3 stuff can control VVT. I don't know that there is any default programming for it so there might be a learning curve there but they have the capability.
68 Barracuda Formula S 340
Re: VVT computer [Re: Bad340fish] #2696165
09/10/19 02:30 PM
09/10/19 02:30 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
What are the ford and Chevy guys running on their vvt engines? Or is it a mopar only thing? Megasquirt is way more programming than I want to do and I am trying to get away from the factory pcm. Argh it can be frustrating not knowing the new tech out there.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: VVT computer [Re: astjp2] #2696182
09/10/19 03:21 PM
09/10/19 03:21 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
They are probably tuning the factory computer. As far as I know holley doesn't do VVT where the Megasquirt can control about anything VVT including the ford Coyote engines with 4 cams.
The megasquirt stuff is pretty easy if you have a good knowledge of how an engine works. Holley might be a little easier but there is still tons of user input.
Re: VVT computer [Re: astjp2] #2696641
09/11/19 06:06 PM
09/11/19 06:06 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
DIYHemi.com on FB has a harness they sell to run the factory stuff. Pretty affordable as well
