Trucks with factory tuff wheels #2695916
09/09/19 07:54 PM
09/09/19 07:54 PM
Midwestern Indiana
duster2 Offline OP
duster2  Offline OP
Midwestern Indiana
Was there anything different about the automatic transmission shift lever
on a truck that had a factory tuff wheel installed vs a truck without a factory
Tuff wheel installed from the factory ???
This question was asked of me by a friend ..
Frank
Re: Trucks with factory tuff wheels [Re: duster2] #2695941
09/09/19 08:55 PM
09/09/19 08:55 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Should be nothing . . .
Re: Trucks with factory tuff wheels [Re: a12rag] #2696058
09/10/19 09:19 AM
09/10/19 09:19 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The steering wheel will hit the shift lever IF you don't use the factory adapter. If you try to bolt the Tuff Wheel directly to the column, it will hit. Sounds like that's his problem if he's asking about the shift lever.
Re: Trucks with factory tuff wheels [Re: burdar] #2696077
09/10/19 10:41 AM
09/10/19 10:41 AM
Midwestern Indiana
duster2 Offline OP
duster2  Offline OP
Midwestern Indiana
He is using a factory adapter , I think the issue is , he thinks the lever should be at a different angle and length
to look and work correctly with the factory tuff wheel.
Frank
Re: Trucks with factory tuff wheels [Re: duster2] #2696135
09/10/19 12:55 PM
09/10/19 12:55 PM
a12rag Offline
a12rag  Offline
you HAVE to use the adapter to mount the Tuff Wheel . . .
Re: Trucks with factory tuff wheels [Re: duster2] #2696247
09/10/19 06:01 PM
09/10/19 06:01 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
depending on the year, yes..
like a 77 truck had large wheel--vs.--tuff wheel....hence different length shift lever
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Trucks with factory tuff wheels [Re: dynotune440] #2696324
09/10/19 09:48 PM
09/10/19 09:48 PM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
The factory auto shift lever for a tuff wheel was shorter that a truck with a standard wheel. Regular shifter is 9 3/4" from roll pin to tip of the shifter handle. Tuff wheel shifter is 8 3/8". My understanding of Tuff wheel on a truck was first year available as a factory option was 78. Based on this fact I probably own the first factory equiped truck with a tuff wheel. My 78 Adventurer SE step side 440 truck is a super early78. It is vin# 21.
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: Trucks with factory tuff wheels [Re: adventurer] #2696390
09/11/19 05:39 AM
09/11/19 05:39 AM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
My 60k mike 77 Warlock had a factory tuff wheel.
I may have shots of the equipment decal.
Red
Re: Trucks with factory tuff wheels [Re: BIGGERED] #2696461
09/11/19 10:34 AM
09/11/19 10:34 AM
Midwestern Indiana
duster2 Offline OP
duster2  Offline OP
Midwestern Indiana
Thanks , I will relay this info...
Frank
Re: Trucks with factory tuff wheels [Re: adventurer] #2701170
09/26/19 03:41 PM
09/26/19 03:41 PM
dynotune440 Offline
dynotune440  Offline
for a stand alone option standpoint, the tuff wheel was available by itself starting in 78, but was apart of the Warlock Option Package on 2wd Warlocks.
