A friend just picked up a 340 x block motor complete with 0 hours on it. The original owner passed away and his 78 yr old father sold it to my friend for $850. It has a high rise dual plane manifold, mech fuel pump, billet distributor with gm hei style cap and coil, aluminum valve covers, chrome deep sump oil pan and new bellhousing and clutch assy. He has a nearly new Holly carb, vac secondary 650 cfm'ish. (Will verify model and cfm in a couple days) I'm reccomending putting it on an engine stand, taking the heads and oil pan off to clean the dust and sand out and to verify condition of cylinders as well as to be able to document internal parts as it's sat for several years outside with a piece of sheet metal and a brick on the intake.
My question to you all is what would you do with this? We're in NM so there are quite a few rust free vehicles to be found around here on the cheap. My friend isn't particularly a fan of Mopars, I have Mopar tattooed on my arm. He would likely drive the finished car around for awhile then look to sell it, perhaps up north in Minesota. I'm thinking a 72 - 74 Duster perhaps but I'm not sure what trans to look for. I would like to see him get a good profit for his efforts, almost stealing the motor being a great start, or should he just try and flip the motor as is?
Y'all are the experts now, what do you suggest? Thanks in advance for you time and considerations/suggestions.
