with the 12" spring you can use a lighter weight spring with the same ride height and get more store energy for better travel.
Thanks. That makes sense. It'll be driven on the street, so I'll definitely have to make a compromise as far as spring rate. I'm leaning towards the 12" for the additional flexibility.
What kind of shock? What kind of installed shock and spring length are you looking at @ ride height?
Using the long shocks on the front usually results in WAY more front end travel than desired or needed and usually some type of limiter to be used in a fast race car.
It's an adjustable coil over and I'll run them at about 13" ride height. Not sure on the spring ride height yet. That'll depend on the spring rate I end up going with. At that particular shock ride height, I can get away with either a 10 or 12 in spring.
The shocks won't be the limitation for front end travel - I have bumps stops for that. I'll be able to tailor how much travel the front end has by simply adjusting the bump stops. The car won't be what I'd call fast, and I already had the shocks, so I figured I'd try them for free.
