10" vs 12" coil over spring? #2695189
09/07/19 11:41 AM
09/07/19 11:41 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I'm building a street/strip 66 Dart. I've converted the front end to coil overs and can either run 12" or 10" springs with the shocks I've got. Is there a reason to use one over the other? Which one is preferred - or does it even matter?
Re: 10" vs 12" coil over spring? [Re: mopowers] #2695213
09/07/19 12:18 PM
09/07/19 12:18 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
with the 12" spring you can use a lighter weight spring with the same ride height and get more store energy for better travel.
Re: 10" vs 12" coil over spring? [Re: plycuda] #2695223
09/07/19 12:51 PM
09/07/19 12:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
What kind of shock? What kind of installed shock and spring length are you looking at @ ride height?
Using the long shocks on the front usually results in WAY more front end travel than desired or needed and usually some type of limiter to be used in a fast race car.
Re: 10" vs 12" coil over spring? [Re: CMcAllister] #2695294
09/07/19 08:01 PM
09/07/19 08:01 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks. That makes sense. It'll be driven on the street, so I'll definitely have to make a compromise as far as spring rate. I'm leaning towards the 12" for the additional flexibility.
It's an adjustable coil over and I'll run them at about 13" ride height. Not sure on the spring ride height yet. That'll depend on the spring rate I end up going with. At that particular shock ride height, I can get away with either a 10 or 12 in spring.
The shocks won't be the limitation for front end travel - I have bumps stops for that. I'll be able to tailor how much travel the front end has by simply adjusting the bump stops. The car won't be what I'd call fast, and I already had the shocks, so I figured I'd try them for free.
Re: 10" vs 12" coil over spring? [Re: mopowers] #2695300
09/07/19 08:41 PM
09/07/19 08:41 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
bump I was always under the impression there is no downside to using the longest spring possible that will not coil bind as long as it gets the job done, or no reason to use a shorter spring if space for longer allows, we are assuming spring rate is chosen correctly for the application.
Re: 10" vs 12" coil over spring? [Re: jcc] #2695313
09/07/19 09:25 PM
09/07/19 09:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
To answer the question, I would use a 12" spring. A light 12" spring compressed to fit in the same length area as a heavier 10" spring, that is not compressed nearly as much to hold the shock at ride height, will make the suspension more "lively" to help with pitch rotation. A decent adjustable shock and/or limiting the travel can be used to control it.
Re: 10" vs 12" coil over spring? [Re: CMcAllister] #2695793
09/09/19 01:42 PM
09/09/19 01:42 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks for the input. Looks like the 12" spring is the way to go.
