Re: RMVB
[Re: 426lloyd]
#2695258
09/07/19 03:56 PM
09/07/19 03:56 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you want to risk blowing the rear clutch seals and stripping the front planet splines, by all means do so. If not, install the spring and forget the blocker.
Some RMVB's don't feed the accumulator so, in that case, the point is moot.
Re: RMVB
[Re: moparx]
#2695462
09/08/19 01:37 PM
09/08/19 01:37 PM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
If separator plate covers the accumulator bore then it does not utilize (feed) the accumulator piston. See attached pics.
Blue plate with cadmium plated reinforcement plate covers the accumulator bore. Second picture shows open circular area below piston bore.
Attach a picture of the valve body if possible.
